Question about Motovox MVS10 43cc 2 Hp 2-Stroke Gas-Powered Stand-Up Scooter
43cc motovox will start and run ok for a couple of mins. then loses power and dies . Checked compression hot and cold OK , new carb and spark plug didn't help.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
When it stops immediately check for spark if no spark when warm but spark when cold suspect ignition coil or related component
Posted on Jan 22, 2015
IHAVE A CUB CADET 173CCOHV SELF PROPELED WON'T START NEW PLUG GAS TO THE CARB OK OK AIR FILTER OK CLEANED CARB STILL WON'T START.
got to have fuel, spark, air and compression. your missing one. be sure plug is good. give it a shot of carburetor cleaner. if it starts and dies it is fuel. check compression. take off valve cover and be sure valves are working as they should and gaped correctly.
Oct 24, 2016 | Cub Cadet Garden
Why does my petrol mower not restart when hot?
carby settings must be good if you get a good start
first
try a new spark plug and check spark when hot
could be a faulty coil.....ok when cold .. no good hot
or rings losing compression or leaking valves
Aug 06, 2016 | Garden
I have a motovox mvs10 43cc 2hp gas powered scooter and was wondering if there is suppose to be plastic like components in fuel tank and what are reasons that could cause it not to start.
often the is a fuel filter in the tank at the end of the fuel line, if it has deteriorted then yes it could stop it from starting due to a clog in the carb. If ou have good spark then sprat a few puffs of starter fluid into air intake or on the air cleaner ( which should be clean ) . if it starts for a second or two then it's most likely your carb.
Nov 23, 2014 | Motovox MVS10 43cc 2 Hp 2-Stroke...
Jet ski loses power when it gets hot
are all cylinders working ? carbs might need cleaning ! what compressions have you ? 100psi min !!
Nov 15, 2013 | Tempest Kawasaki Jet Ski 1100cc JT1100 STX...
I replaced the fuel pump 3 weeks ago, and it mowed ok twice. Now it sputters and wants to stall when I engage the PTO. The fuel filter is new and clean and there is nothing interfering with the blades.
Have you checked spark plugs? I always check the "BIG" three when diagnosing any engine. Compression, spark, and fuel. I recommend buying a compression tester and a spark tester. Check both of those, if ok then make sure your still getting fuel to the carb. If so, try a shot of starting fluid through the aircleaner, if it starts on starting fluid then dies, you have a dirty carb. I would first of all replace plugs and give this unit a tune up. Good luck and happy wrenching!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 08, 2013 | John Deere Tractor Starter 285 345 2243...
Got a craftsman leaf blower cranks up and runs fine for about 5 mins then starts losing rpms
ITs hard to diagnose these things over the internet, it could be so many things.
Is this a gradual loss of power? If so; Im sorry to say; that it sounds like its losing compression as it warms up. It is not cost effective to repair the unit.
If the loss of power is more sudden it could be a failing ignition module. Ive even seen spark plugs that quit working when they get hot.
To test this you will need a proper spark tester, laying the spark plug against the head will not provide an accurate assesment, and a can of carb cleaner. Run the unit with the air box cover and filter removed till it fails and immediately give a shot of carb cleaner in the carb and restart. If it starts right up it could be fuel related. IF it doesnt start right up then quickly test for spark. If no spark then its likely the ignition module. If it wont run on the extra fuel and it has spark then it has probably lost compression.
Nov 05, 2012 | Craftsman 4 Cycle Blower/Vac
2007 Gilera DNA 50 loses power when hot
Hi, Dratmanl9 and the usual suspects are:
1. Faulty ignition coil.
2. Faulty spark plug cables.
3. Faulty temperature sensor.
4. Faulty starter motor.
5. Valves adjusted too tight.
6. Spark plug gap too wide.
7. Fuel has vapor lock.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
GILERA DNA 50CC BOGGING DOWN SOMETIMES WHEN RIDING HELP
The MotorBike Forum
Gilera DNA 50 Workshop Manual
Gilera DNA 50 2002 Parts
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 18, 2017 | 2007 Gilera DNA 50
Stihl bg 55 blower runs good for 5 min. then loses power
1) carburetor gaskets/diaphragms may need to be replaced
2) ignition coil may be breaking down when hot
3) check compression when cold, then after it stops, when hot
4) could have a vacuum/pressure leak
*I would investigate carb first
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 08, 2009 | Garden
Chainsaw will not start
Remove muffler and check for carbon blockage.
If that is ok check crankshaft seals for leakage.
Mar 14, 2009 | Poulan Garden
Motovox MVS10 43cc 2 Hp 2-Stroke Gas-Powered Stand-Up Scooter Logo
292 people viewed this question
Top Motovox Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Motovox Garden Expert? Answer questions, earn points and help others
