Question about Frigidaire FDE647RF Dryer
Kenmore he2 dryer model 110.87561603 how do you remove the drum roller?
My dryer won't spin and is squeeling
It sounds like either the belt is loose or the drum is frozen. Try the following links to see if they help.
Appliance411 Home Service Appliance Repair Manual for Whirlpool Kenmore...
This will help if you have never repaired a dryer.
User Manual Downloads
Feb 05, 2016 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
How do I get to drum rollers kenmore he2
Lift top and tilt back, remove 2 top screws and 2 bottom screws, remove wires from door switch, lift front up a inch and pull out of drum and set front off to the sides. Rollers are attached to rear panel, remove roller retainers, and replace rollers, then reassemble.
Jul 26, 2015 | Kenmore Dryers
Kenmore he2 dryer is makinga loud noice when drying clothes
Hi Ralph Romero
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Oct 01, 2012 | Kenmore Dryers
My Kenmore HE2 dryer is squeaking. I already replaced the rollers, pulley, and belt. What can I try next?
Hi chrissybeals...
Did you lubricate the rollers with a good grade of machine oil or vasoline before you reinstalled them?
If not then that could be where your noise is coming from.
Also one other thing you can check, make sure your felt dust seal on the front of the drum is good shape and does not have worn or torn spots in it, it also can make noise.
You can also take the machine apart, remove the drum and set it off to the side, and run the motor by itself to see if it is making the noise.
Aug 18, 2011 | Hotpoint TDC32 Electric Dryer
Squeaking on start up of electric dryer 110.8756 HE2
REPLACE IDLER PULLEY AND DRUM ROLLERS THERE IS A KIT COMES WITH NEW ROLLERS IDLER PULLEY AND BELT GET YOUR MODEL NUMBER CALL LOCAL APPLIANCE PARTS DISTRIBUTOR
Jan 25, 2011 | Kenmore Dryers
My Kenmore Dryer Model 65732 drum won't turn. I opened up the front so that I could see the drum and I can see that the belt is okay. I can also see that the rear drum seal has deteriorated. Can anyone...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2010 | Kenmore Dryers
One of the baffle fins are loose inside my Kenmore HE2 dryer. How can I tighten?
you can lid or remove the lid to gain access to the screws on the drum vanes.turn the drum by hand to get all the screws tight
Apr 21, 2010 | Kenmore Dryers
Kenmore series 70 dryer gas model 76712693-76712 squealing
Raise the top.
Remove the front panel.
Remove the drum.
Remove and replace the drum rollers and the belt tension roller.
Jan 20, 2009 | Kenmore 72982 Gas Dryer
Kenmore HE2 Dryer Blades Loose
Yes. Depends on your model. The top, front and rear come off of some. Very easy fix. Your screws should be on the floor under the dryer.
Jan 08, 2009 | Kenmore Elite HE4 Electric Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
