Question about RCA R52WH73 Projection Television
Tv gos off turn on it gos right off will not stay on r52WH74
  • sbrimer2002 May 11, 2009
    My tv goes off and sometimes it will go to the password menu for parental control and tell you to deacitvate it. It likes it is on a timer. We do not have a password. Do not know how to set one with the remote. Help!!!!
    Genius:
  • 1,030 Answers
The trouble with the tca itc 222 chasis is that there is about 25 different resons that what you describe called a shutdown condition will occur. The first thing to know is that its not a main fuse problem.. the processor is recieving power and is detectecting a condition that is causing it to shutdown for safety. The top reason for this shutdown include a shorted Horizontal Output transistor, A bad flyback transformer. There has been reports of bad capacitors cp150, Technicians have special computer equipment that they plug in to read "error codes" that can help determine the problem. unfortunatly unless your a techniction these sets can be trouble to work on. I work on these daily and still they are trouble
Posted on Apr 24, 2009
Screen wont stay on
make sure the remote button ain't stuck or make sure that its set on the correct stations.
May 05, 2012 | Polaroid TLA-01911C TV
My R52WH74 projection tv is giving me a code 9 then 5 blinks
Replace the deflection board. You need the ITC222A deflection board PSB-260 available with installation instructions from www.tvrepairworld.com
Jul 07, 2010 | RCA R52WH73 Projection Television
We have a Sharp 32 inch flat sceen TV , when we turn on cable the tv at first comes on but than gos blank. We have to manually turn on TV inorder to get the TV to stay on. We have to do this several times...
No Solution sorry, but can sympathise. Our TV does the same thing. We had it repaired two years ago (when under warranty) but I fear the cost would not be worth it now.
May 17, 2010 | Sharp Televison & Video
I have a RCA R52WH74. When you turn it on there's
replace the deflection board. You need the ITC222A deflection board PSB-260 you can get a replacement deflection board from www.tvrepairworld.com which also has the CD that shows how to remove the old board.
Apr 11, 2010 | RCA HD52W56 52" Rear Projection HDTV
I too cannot get the TV to turn on but my model is a R52WH74
the chasis number of your tv is eithor itc222 or itc221 the deflection board causes most of the problems part number 258762 part discontinued but you can contact eithor pts electronics or tristate module to see if they can fix yours
Sep 02, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA r52wh74 tv powers on then powers right off
one solution to maybe solve the problem of it not staying powered would be to take the panel off the back and use a blow dryer in the lower left hand corner and heat it up. It worked to get our tv turned on.
Jun 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
HDTV R52WH74 TV WILL NO TURN ON
I would contact RCA support, and they should be able to provide you with the authorized RCA service centers in your area.This is the RCA customer Service number 580-634-0151
Jul 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WH73 Projection Television Logo
265 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
