Question about Casio Protrek Triple Sensor Tough Solar PRG-90-3VDR Watch
PS C displayed bottom left corner with C flashing. watch has locked up
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    How do I set the time on a philippe starck ph1110? There aren't any buttons to push...
    hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker
    Dec 30, 2011 | Watches
    The date on the f91w watch it's wrong, how can I modify it. Thanks in advance for your help.
    The time or date is adjusted by pressing the lower left button three times to bring the watch to time adjustment mode. This causes the seconds to flash on the display. The top left button is pressed to cycle through seconds, hours, minutes, month, date, day, and normal mode. The right button is then pressed to adjust the flashing value displayed. When the adjustments are finished, the bottom left button is pressed repeatedly until the watch returns to normal mode.
    Feb 28, 2011 | Watches
    My watch is stuck on military time somehow. I would like to know how to change it back to normal time. My watch is a Armitron Alarm/Chrono WR 165 sports watch. The number on the back is 45/6915. Thanks for...
    Welcome to Fixya,
    The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
    1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
    2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
    3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
    4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
    5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
    6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
    I hope this will help you.
    Thank you for usinf Fixya.
    Feb 21, 2011 | Watches
    How do i change display color?
    Hold the top left button down until you hear a beep and the seconds start to flash. Then push the bottom left button (7 times) until COL starts to flash above the seconds. At this point, you can use the 2 right buttons to scroll through the color options. When you're done, press the top left button to set and lock the color you've chosen. Hope that helps.
    Dec 20, 2010 | Casio G-Shock G3110-1V Wrist Watch
    I have a g shock riseman g-9200, what does the letters PS mean(just to left of hour in time keeping mode, also is there any indication that i am getting a atomic time keeping signal?.......Thanks.....syd
    PS means the watch is in power save mode if there is an indicator under the PS on your watch. this means the watch will go into a sleep mode when it is left in the dark for extended periods. change this setting by holding the top left button until a city code starts flashing, then press the bottom left button until "PSON" is flashing , you can switch between "PSON" and "PSOF" in this way by pressing the bottom right button. i, and casio recommend leaving the watch in the powersave mode though to help extend battery life. I got all this info from my G Shock manual.
    Jun 12, 2010 | Casio GShock Riseman AltiTherm GW92001...
    Reset watch
    Hi
    Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
    TIME SETTING--
    1. Push the bottom right hand button until the mode hand indicator points to TME.
    2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
    3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
    4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
    5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
    6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
    7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
    8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
    9. Push the lower right button back in.
    SET THE CALENDAR--
    1. Push the bottom right hand button until the mode hand indicator points to CAL.
    4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
    5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
    6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
    7. Push the lower right button back in.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Aug 31, 2009 | Watches
    Setting atomic receiving mode
    There are two three-bar displays on this watch.
    The three in the top left will always show only one bar (or possibly no bars).  The top left indicates the level of charge in the battery and not the atomic receive function.
    The three in the bottom right are related to receiving.  The atomic receive is controlled from settings.  With the time displayed, hold down the ADJUST button for several seconds.  Once the timezone name (e.g. LAX) starts flashing at the top, release the ADJUST button and press MODE once to get to the DST control. Press MODE again to get to the Atomic receive control.  Use the receive button to switch ON->OFF->ON... Press ADJUST twice to exit settings mode.
    Nov 02, 2008 | Casio Atomic-Solar MTG900 Watch
    Timex Watch
    While the time is displaying on watch press & hold the set/indiglo or top left button on watch. The seconds should start to flash.
    Press the mode or bottom left button until the hour digits start to flash.
    Press top right or start/stop button to advance the hour. Then press top left or set/indiglo button to exit set mode.
    Mar 09, 2008 | Timex Ironman 30 Lap 53952 Wrist Watch
    Casio Protrek Triple Sensor Tough Solar PRG-90-3VDR Watch Logo
    56 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
