Question about Windchaser OCWR161 Wall Mount Fan
Remote does not turn on the fan. It's the only way to turn on this fan!
  • davidgbishop Apr 23, 2009
    You are talking about ground and power wires coming into the control unit (not the remote) Correct?
    Thanks..
    Brigadier General:
  • 3,917 Answers
HI,
The original connector was not assembled properly. If the original was a twist on type, then unscrew it. Otherwise, remove the connector by cutting it off with cutting pliers. Now strip back insulation from the 2 wires about 1/2 inch and then twist the 2 together. now screw on a wire connector (tightly) that you must purchase (sorry) in an electrical hardware store. Finally, wrap electrical tape around both the new connector and wires to prevent unraveling.
Note: If your fan is under warantee then donot try the above steps.
Thanks
Posted on Apr 23, 2009
  • e-Guru
    e-Guru Apr 23, 2009
    Thats correct. Nothing from remote.
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
Remote required to turn on light but fan turns on with light switch
Before you conclude the fan was wired incorrectly, try this:
1. Shut off power to the fan (at the circuit breaker)
2. Remove batteries from the remote and press all the buttons to eliminate the possibility of a stuck button. Reinstall batteries
3. Turn on power to the fan and try operation
Jan 23, 2013 | Hunter 28096 Westminster 52" Ceiling Fan...
Fan light turns on but doesn't turn off with remote also fan doesn't go on with remote
Make shure your batteries are good in the remote. Also some remotes have little dip switchers inside the battery cover that are either on or off. They must be in the same position as the dip switches on the receiver in the top canopy of the ceiling fan or the remote & receiver won't talk to each other. Apart from that you will probably need to replace the remote control & receiver unit.
Dec 12, 2012 | Hampton Bay 52 In.Carriage House II in...
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
Two fans with the same remote code.
There are dip-switches in both the remote and the fan. You need to change the switches on one of your fans.
Jul 14, 2009 | Universal Remote Control Hampton Bay...
Ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Dec 28, 2008 | Hunter 52" Ceiling Fan With Light And...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Windchaser OCWR161 Wall Mount Fan Logo
115 people viewed this question
Top Windchaser Dryers Experts
john h
Vernon Taylor
Are you a Windchaser Dryer Expert? Answer questions, earn points and help others
