Question about Sony ICFC11iP/BLK iiPhone R/Pod R Dock Clock Radio with Light
Not syncing with the iPhone - Sony ICFC11iP/BLK iiPhone R/Pod R Dock Clock Radio with Light
I want to sync iPhone to iPad.
  1. Open iTunes. ...
  2. Use the USB cable that came with your iOS device to connect it to your computer.
  3. In iTunes, find and then click your iOS device.
  4. On the Summary tab, select "Sync with this [device] over Wi-Fi."
  5. Click Apply, then disconnect the USB cable.
Sep 30, 2016 | Cell Phones
Sync Contacts in Address Book from computer to iPHone.
On your iPhone, make sure that
  • in the Settings app
    • Mail, Contacts...-->iCloud has Contacts enabled (green button)
On your Mac, make sure that
  • System Preferences-->iCloud has Contacts checked.
If the iPhone still doesn't sync,
  • connect the USB cable from the iPhone to the Mac,
  • open iTunes,
  • make sure that "automatically sync iPhone when connected" is checked in the Summary window of your iPhone (in iTunes);
  • and click "sync" in the lower right corner of your iTunes window.
Feb 10, 2015 | Apple iPhone 5
IPhone deletes my contact names when I sync it to computer! Leaves the numbers, delete only names.
If you've set up automatic syncing, iTunes syncs your device by default whenever you connect your iPod, iPhone, or iPad to your computer. If you don't want iTunes to sync your device without being prompted, you can change this setting.
You can prevent unprompted syncing for any specific iPod, iPhone, or iPad; or for all iPod, iPhone, or iPad devices you connect to your computer.
To prevent unprompted syncing for a specific iPod, iPhone, or iPad:
  1. Connect your iPod, iPhone, or iPad to your computer.
  2. In iTunes, select your device (below Devices).
  3. Click Summary, and then deselect "Open iTunes when this Device is connected."
To prevent unprompted syncing for all iPod, iPhone, and iPad devices:
  1. In iTunes, choose Edit > Preferences.
  2. Click Devices.
  3. Select "Prevent iPods, iPhones, and iPads from syncing automatically."
    If this checkbox is selected, any connected iPod, iPhone, or iPad won't sync without being prompted.
To sync your iPod, iPhone, or iPad when unprompted syncing is disabled, connect your iPod, iPhone, or iPad to your computer, and then choose File > Sync "Device Name" in iTunes, or click your device (below Devices) and then click Sync.
For more information, see the iPod, iPhone, or iPad User Guide or the Apple Support website.
Dec 18, 2012 | Cell Phones
IPhone will not sync music
If you are using iTunes, point to your iPhone, when connected. In the Device section, from the Music tab, make sure that "Sync Music" and "Entire music library" are both connected. Also, go to Apps tab and see if your computer is, indeed, authorized.
And there is a tutorial about sync iPhone music to computer easily, please try to refer it.
Hope it helps.
Oct 23, 2011 | Apple iPhone 3GS Black (16 GB)
Can you sync iphone to your ipad?
iPubsoft iPad iPhone iPod to Computer Transfer is the best choice to backup the data betweent th apple devices, including iphone 3gs/ 4/ 4s/ 5s, ipad, ipod etc. iPubsoft iPad iPhone iPod to Computer Transfer
Apr 07, 2011 | Computers & Internet
How do you remove synced photos from the iphone?
You can do this in iTunes - with the iPhone connected select the 'photos' tab and deselect the folder containing the photos, then hit Sync to remove them.
Alternatively, just move the photos to a different location on your hard drive (out of any folder that is set to sync to iPhone), then connect to iTunes and hit sync.
Hope that helps!
Oct 30, 2009 | Apple iPhone 3G
Need help syncing to IPhone
Just load your iTune library with items with you wants to sync. The connect your iphone & click on Sync button on iphone. Then syncing will start. If you enabled automatic syncing then your iphone will automatically sync while you connects to iTune.
( Note: Do not disonnect your iphone while syncing in progress it will reason for data loss.)
Thanks.
Happy to help you.
Sep 26, 2009 | Palm Zire 31 Handheld
Sync iphone to outlook contacts
Speaking of syncing iPhone with Outlook, you can take advantage of iTunes to sync contacts. sync-iphone-outlook-contacts-oxaxc0rwhkhzilrwacqreyis-3-0.jpg
  1. Connect iPhone to computer with USB cable, and launch iTunes.
  2. Click iPhone icon, and choose Info the Summary Panel in left sidebar.
  3. Check Sync Contacts with, and choose in the drop-down menu.
  4. Click Apply at the right bottom to start syncing iPhone contacts with Outlook.
When the sync is finished, the contacts will show up in the Outlook contacts. Besides syncing contacts, you can also sync iPhone calendars and mails to outlook as well. But if you have noticed, the sync of iTunes is an annoying issue among iPhone users as during the sync of iTunes, the application may erase the available files in their iPhone.
http://www.leawo.org/tutorial/how-to-sync-iphone-with-outlook.html
Jul 19, 2009 | Apple iPhone Smartphone
How to sync .ipa files from comp to iphone thru itunes ?
when you sync the iPhone with the computer, iTunes will only add what is new, it will not delete your apps.
Setting Up Syncing You use iTunes on your computer to set up which items are synced. Make sure you have the most recent version of iTunes (On a PC, open iTunes and choose Help > Check for Updates. On a Mac, open iTunes and choose iTunes > Check for Updates.
Step 1: Connect iPhone or iPod touch
  1. Connect iPhone or iPod touch to your computer using the included cable. You can connect the cable from your computer directly to iPhone or iPod touch, or connect the cable from your computer to the Apple Universal Dock (available separately) and put iPhone or iPod touch in the dock. By default, iTunes opens automatically.
  2. Select iPhone or iPod touch in iTunes under Devices on the left hand side and click the Info tab.
Step 2: Set Up Which Items Are Synced Click the respective tabs in iTunes to specify which media and information you want synced from your computer to iPhone or iPod touch.
For more information about syncing iPhone with your computer see the iPhone User's Guide:
On your computer: click here to download and view "Chapter 1: Getting Started" in iPhone User Guide.
On iPhone: Tap Safari and view http://help.apple.com/iphone/guide/.
For more information about syncing iPod touch with your computer:
On your computer, click here to download and view "Chapter 1: Getting Started" in iPod touch User Guide.
On iPod touch: Tap Safari and view http://help.apple.com/ipodtouch/guide/.
Step 3: Sync iPhone or iPod touch Click Apply in the lower-right corner of the screen. Your computer syncs with iPhone or iPod touch according to your settings.
The first time you sync iPhone or iPod touch, you are asked if you want to merge data, replace data on the service, or replace the data on your computer. After that, anytime you connect iPhone or iPod touch to your computer, iTunes opens and syncs with iPhone or iPod touch according to your settings.
You can adjust sync settings anytime iPhone or iPod touch is connected to your computer. You can only connect and sync with one iPhone or iPod touch at the same time. If you need to sync more than one iPhone or iPod touch, disconnect one before connecting the other.
Note: Syncing won't delete any contact in Yahoo! Address Book that contains a Messenger ID, even if you've deleted the contact from your address book on iPhone or your computer. To delete a contact containing a Messenger ID, log in to your Yahoo! account online and delete the contact using Yahoo! Address Book.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Apple iPhone Smartphone
How to sync contacts from iphone to outlook 2003?
When you connect your iPhone to the PC that you always sync with, Go to Info tab, Check the box Sync Contacts with: and select Outlook. Then make sure that you check the box Put new contacts created on this phone into the group: and select a subfolder in your main contacts folder.
This way, all the contacts from your iPhone will be saved into another folder in your main contacts folder of your Outlook PST.
Let me know if you have any questions.
Thanks
Sandeep
Jan 30, 2008 | Apple iPhone Smartphone
Sony ICFC11iP/BLK iiPhone R/Pod R Dock Clock Radio with Light Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
