Question about Moultrie Game Spy M80 Infrared Digital Game Camera
Camera needs to be reset - Moultrie Game Spy M80 Infrared Digital Game Camera
My IBM computer doesn't recognize when I plug in the usb camera patch cord and even the display goes blank on the camera. So do I need a new driver or camera
Welcome to Fixya
Did you accidentally dropped the camera? You should be able to see options when you plug in the camera to your computer. Try to reset the camera first to factory state as part of our initial troubleshooting.See procedure below:
Select reset settings icon Press set button Reset setting screen should appear then press YES Press the SET button Camera setting should be reset then test the issue again
Thank you for using Fixya!
Jun 10, 2011 | Sanyo VPC-C5 Digital Camera
I need to' reset The camera . How can i do ? Thanks
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
  • Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Aug 10, 2010 | Sony Cyber-shot DSC-W300 Digital Camera
I need a master reset, hard reset, firmware reset for my Nikon S710. I try with "erase all" but configuration is not equal to the first time use my camera. I need reset my camera. Thanks.
Two methods...scroll to "reset" in the setup menu and follow the on-screen instructions. -or- Remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
Sep 24, 2009 | Nikon COOLPIX S710 Digital Camera
I have a sony cybershot dsc-f707 Icant zoom in or out only after I take a picture. I also wanted to know if I need to charge the lense to zoom?
Option 1:
Reset the Camera and check if it helps to resolve the issue.(Resetting the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera).
The RESET button is located inside the battery/ Memory Stick cover. The Camera should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
Use a fully charged Battery in the Camera so that the Zoom function work normally.
Aug 27, 2009 | Sony Cameras
My computer is not recognizing my L16 Nikon coolpix
I would suggest to resetting the camera. Each camera has a different procedure, but most cameras can be reset by removing the batteries for several minutes then replacing them and turning the camera back on. If that doesn't work, then read in your manual under "reset" or "initialize" camera.
Or you need to download the driver of the camera again...
Jul 01, 2009 | Nikon L16 silver Digital Camera
Master Reset Olympus x840
To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight yes and press ok. This will set the camera back to factory default settings. Hopefully this should solve the issue.
Apr 13, 2009 | Olympus FE-210 Digital Camera
Need to factory reset E-Volt 500 Digital Olympus Camera
Put camera dial on P - go to Menu - camera 1 tab is highlighted - right arrow over to card setup - down arrow to custom reset setting - right arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera should now be in factory default settings
Dec 24, 2008 | Olympus EVOLT E-500 Digital Camera
Htc touch camera doesnt work... did soft and hard reset n tried to start camera app. from windows folder but no response....help needed !
Among the many issues with the Touch, the camera is another. If a hard reset doesnt work, your device will need a new camera. If you have Sprint, this can be replaced at any service center for no charge if you have insurance and there is a part for immediate repair.
Just to confirm, when you do a hard reset make sure that you press and hold both of the softkeys while sticking the stylus in the reset hole until it asks to reset.
Dec 17, 2008 | HTC Touch P3450 Smartphone
Reset my camera vivicam 3710
The reset is not the camera, its the batteries. If you are using regular batteries its time for new ones. IF you are using rechargeable, then they either need to recharge, or have used their life expectance. Try putting in regular batteries and see if they work. If they do, you need a new rechargeable cell. Please let me know if this works for you! Thanks //D
Sep 29, 2007 | Vivitar ViviCam 3710 Digital Camera
Moultrie Game Spy M80 Infrared Digital Game Camera Logo
32 people viewed this question
Top Moultrie Home Security Experts
Anthony Pattay
Level 1 Expert
 Mikey
Mikey
Are you a Moultrie Home Security Expert? Answer questions, earn points and help others
