Question about Ellington AW52MBK5 All-Weather Matte Black Ceiling Fan
Heller ceiling fan is slow on high setting- why?
My hunter ceiling fan turns very slow
Check your capacitor. If this is an add on remote, set the fan on high with the remote then pull the chain on the fan until you get high speed.
Sep 17, 2014 | Hunter 52" Ceiling Fan With Light And...
Just installed a heller ceiling fan with remote, it works fine from the remote but the light nolonger works from the light switch
All the switch on the wall does is turn the power on/off. You have to do everything from the remote with the wall switch on.
Dec 27, 2013 | Hampton Bay 24002 Ceiling Fan
On its own went from low to high speed and can't slow it down
Windings in the motor shorted out or the switch shorted out.
Sep 11, 2012 | Hampton Bay Ceiling Fan. Altura 68 in....
Ceiling fan runs slow on highest setting. Or not a all on lower settings. Motor hums so it is try ing to work.
Sounds like something is binding. If you have full voltage on the fan and you can't find the source of what is binding, you will have to replace it.
Apr 09, 2010 | 2003 Oldsmobile Silhouette
Heller fridge keeps freezing up at the rear of the fridge
Model # would help!. The symtoms relating could be of a # of issues depending on the design (model #). Cold control, defrost issues, non or slow moving evaporator fan, slight pressue loss (undercharge), partial restriction, extra ambiant heat.
Ric
Mar 09, 2010 | Refrigerators
New Hampton Bay ceiling fans spin too slow
Slow spinning of the fan might be caused by a low voltage. Is there any way you can measure the voltage, and if the wires are properly connected, check for any loose wiring or rust in between connections. Maybe the breaker that supplies power to the fans has a loose connections inside, try putting a new breaker of same rated current. Check if those three fans are connected to the same breaker. Breaker can go bad from the inside not doing a proper connection and supplying a low voltage, this might be causing the slow spinning of the fan. Second the black box in the space with all the wires is called the capacitor.
May 30, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Ceiling fan stopped working after power spike blew the breaker. I reset the breaker and all else in the room came on but not fan. Does it have an internal reset?
If you own a Hunter Original, there is no reset button, but MANY people that have a remote control added (includng me) have , once power has been restored, found that the chain was pulled by someone and it got into the off position, rather than the slow, medium or high setting. With the circuit hot, pull the chain one more time and try to turn on your fan with the remote again.
Hope this helps.
Jun 20, 2008 | Hunter 23852 Classic Original Ceiling Fan
Altura 68" Ceiling Fan
That's because it's 68" across, even though it uses the name motor inside as a 52" fan.
Jun 19, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Ellington AW52MBK5 All-Weather Matte Black Ceiling Fan Logo
23 people viewed this question
Top Ellington Dryers Experts
john h
Bill Boyd
Are you an Ellington Dryer Expert? Answer questions, earn points and help others
