Question about Lexmark Optra T614 Laser Printer
Invalid engine code
Printer will not print and I get an error message 'invalid engine code' Printer is Lexmark Optra T614
    Genius:
  • 1,011 Answers
The easiest way to solve this is to work through Lexmark Technical Support.
Their web site may have the correct engine code on their site, but installation of the code can be tricky.
Are you getting a 900 Invalid Engine code message?
Don
Posted on Oct 19, 2009
I have lexmark optra T614 there is a sign: error 954 NVRAM Failure. Please help?
Please click on the link provided below for a more detailed instruction on how to correct the problem.
http://bit.ly/pVmdfz
If you need further assistance please contact Lexmark Technical Support.
Apr 21, 2011 | Lexmark Optra T614 Laser Printer
Lexmark optra t610 invalid refill error change cartridge......how do i reset the printer to disable the error
The error may not be specifically a toner cartridge problem but may be due to a stuck cover open switch on the printer. Perhaps this article on Error: "Invalid Toner Cartridge" or "Invalid Refill" will be able to determine the root cause of the problem. Just click on this link: http://bit.ly/dupj2m. Just make sure you are using a genuine Lexmark toner in the printer. If you need further assistance, you can also contact Lexmark technical support. Thanks.
Sep 14, 2010 | Lexmark Optra T614 Laser Printer
What does 900 Service RIP Software error message mean and how do i reslove it
If the 900 error occurs only when the printer is receiving information from a network or computer, contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer. To check the base printer:
  1. Turn off the printer and disconnect every cable, except for the power cord.
  2. Turn on the printer and see if the error returns.
  3. If the error does not return, try to print a test page from the Test Menu.
    1. Press Menu > to enter Menus.
      Optra S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
      Optra T and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
    2. Press Select to view the menu items. TESTS/UTILITIES MENU is now on the first line of the display.
    3. Press the Menu > button until Print Menus appears on the second line.
    4. Press Select.
    5. If the display tells you to change paper, press Select or the GO button to print.
  4. If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  5. If the 900 error occurs again before, during, or after the printing of the test page, remove all options (internal network adapters, optional feeders, second drawer options, finisher options, additional memory, etc.) from the printer.
  6. Then turn on the printer and try to print the test page. If it still posts the 900 error, the printer may need to be serviced.
  7. If the error does not return, then the problem may be with one of the options.
IMPORTANT: If you receive an Invalid Engine Code error message when you power the printer back on, there is a problem with the printer. An Invalid Engine Code condition will cause a 900 RIP Software Error message to appear if you try to use the printer. The Invalid Engine Code error means either that your printer has lost its stored operating code for the engine board or that the printer's engine board has gone out.
Aug 02, 2010 | Lexmark Optra T610 Laser Printer
T614 invalid engine code how to fix
Here's an article in the Lexmark website on The Printer Displays an 'Invalid Engine Code' Message. Just click on this link: http://bit.ly/aG7vrC. Read thoroughly the article first. Follow the instructions carefully.
But I would strongly suggest you contact Lexmark Technical Support for assistance, especially if there are options attached to the printer, to make sure all options will function properly.
Jul 06, 2010 | Lexmark Optra T614 Laser Printer
Invalid engine code on screen, what does this mean
An Invalid Engine Code error message may mean that your printer has lost the stored operating code for the engine board. Here's an article in the Lexmark website that will guide you on what to do when encountering this problem. Just click on this link http://bit.ly/cJLGMp. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Apr 20, 2010 | Lexmark Optra T614 Laser Printer
Invalid engine code on Lexmark Optra T610
Sounds like you've experienced a fairly common problem with Lexmark Optra printers. The engine board has more than likely failed. Rather than go to to Lexmark, try this site for a less expensive replacement board...
http://www.partsnow.com//
Apr 19, 2010 | Lexmark Optra T610 Laser Printer
Invalid engine code?
Try putting the old fuser back and see if it gets rid of the error, then if that's the case the new fuser is defective. If not, here's a link to the Lexmark website which gives you instructions on what to do when having that "Invalid Engine Code" error message. http://bit.ly/9D61W3. Hope this helps. Let me know if you need more assistance.
Apr 16, 2010 | Lexmark Optra T612 Laser Printer
Unisys model uds25 has a error message "invalid engire"
on power up let me guess the most frequent errors on power up are 922 fuser error means ac circuit is open replace the fuser. 201 jam error no paper present replace the main motor drive. 954 nvram error hold right arrow go and reutrn buttons down power on the machine if it doesnt reset repplace the engine board this is just a band aid thie error is known to return. there are also several scanner errors that can come up a biy more info would be good
Feb 19, 2009 | Lexmark Optra T614 Laser Printer
Optra T614 printer
i had the same problem and it went away after i removed the main circuit board and reinstalled it. (left side of the machine)
Apr 03, 2008 | Lexmark Optra T614 Laser Printer
Lexmark Optra T614 Laser Printer Logo
701 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
