Question about GE Kitchen Ranges
My GE Spectra model JB600WOD1WW had the lower bake element break and caught on fire. I turned off the oven knob but the fire continued. I then turned off the power to the oven at the breaker. My question is do you think I can replace only the element or did something go bad in the electronics of the stove?
aborcass
  • 2651 Answers
SOURCE: MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Posted on Mar 06, 2008
revamos
  • 16 Answers
SOURCE: Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Posted on Apr 21, 2008
  • 116 Answers
SOURCE: Replaced bake element in JBP90SFSS and now oven not working properly
Sometimes when an element opens, there is significant current to cause the control relays to arc and weld together causing them to act as a closed switch no matter what state the control tells them to be in. This will have to be checked at the control board using a multimeter.
There is significant voltage and current involved in this circuit and testing is best left to a professional.
The back of the range will have to be removed to check the circuit for faults.
Posted on Jul 28, 2008
MNTECH
  • 1543 Answers
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
SOURCE: Whirpool Imperial Series Stove turns off while I'm trying to bake
there is a control board just behind the clock. on that board is an omron g2rl-1a-e-cf, 9vdc, 16/250vac type relay. i replaced that relay with an equivalent wired in one and that fixed the problem.
Posted on Jul 14, 2009
I have a GE spectra JBP24 model. I turned on the oven and in a few minutes noticed a funny light inside. When I opened it up the element was burning. I unplugged the stove and when it cooled down, I went...
This is a common but spectacular occurrence when a bake element fails. You can go to your local appliance parts store with your model # and they may have a replacement element in stock.
Remember to rinse the baking soda out prior to using the oven.
Aug 29, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Oven won't turn on
The most likely problem is that the bake element would have gone bad.Check the wiring that comes off the control board. If you have an ohm meter check the continuity of the bake element if there is continuity then replace the electronic control.If there is no no continuity replace the element.
Thank you!
Jul 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
The coil in my oven caught on fire
You will need to replace the element, If it was just the lower bake element, it is a very easy repair, two screws and two wire connectors. UNPLUG the stove FIRST!!
My lower oven element started to glow white hot so i turned it off . it continued to glow and travel about 6 inches until i pulled the plug, the element now has a break in it. is my control faulty too or...
The element can just be replaced, Sometimes these will start a small fire inside the oven. It's just the element has burned completely out. Some of these are tricky to take out, but it's fairly easy.
Apr 04, 2010 | GE Spectra JBP78 Electric Kitchen Range
Lower oven element doesnt work
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
It will , also, show no continuity when measured with a meter as well.
Jul 12, 2009 | GE Ovens
Turned on self clean on my GE Spectra JBP24B0B4WH Range
Hello Cliff Hendershot,
One USA manual ... said turn off power for 10 minutes
(sounds reasonable after looking up cost of control board)...
USA websites are not responding to your number.
Closest I could get was to a $78 (us dollar) control panel
>> ((IMPORTANT PART ... has a video that shows repair))
http://www.appliancepartspros.com/ge-oven-control-t09-wb27t11312-ap5177950.html
I could NOT get a good READ on your JBP24... page 8
So I attached a JBP19 (below)... Page 12.
The most COMMON reason to FAIL after a cleaning cycle
is your OVEN CONTROL is "off normal"
(You still do not have your MANUAL MODE restored).
Normal = "AUTOMATIC" LIGHT Off (NOT LIT)
Check your "oven controls"
else
Oven elements do break during routine use...
Check both roast & bake elements for continuity.
GE JBP19 Owner Manual Usingthe Oven
Carnac the Magnificent
Jun 08, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 20, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Oven fire
wrong call ge@ 100-851-6200 and they will help you have the model number handy before you call
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Kitchen Ranges Logo
151 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
