Question about Singer Sewing Machines
Singer sew mate 5400 thread bunching and jam - Singer Sewing Machines
  • 155 Answers
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
 thanks.
Posted on Oct 26, 2008
  • 19 Answers
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Posted on Dec 30, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
Mimito7
  • 128 Answers
SOURCE: No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
Posted on Apr 19, 2009
  • 980 Answers
SOURCE: Touch & Sew zig-zag model 758 - bobbin thread
email me for retiming instructions and remind me of your make, drivewithken@blueyonder.co.uk
Posted on Jan 09, 2010
When using buttonhole attachment, machine does not move instead sews in one spot and collects thread coming up from bobbin. Any ideas?
make sure the buttonhole option is chosen
and then pull down the buttonhole lever
it should come down against the buttonhole foot
Apr 25, 2016 | Singer 5400 Sew Mate 60-Stitch Sewing...
Why is bobbin not catching thread?
It could be that the hook timing is adrift but quite likely that the machine is misthreaded or the needle bent. Get a NEW needle, check your handbook for how to insert it and re-read how to thread your machine. The upper thread could be misthreaded or the bobbin not threaded correctly. The bobbin may look like its threaded OK but if the thread is coming off the bobbin in the wrong direction the machine will never see. Hope this helps.
Jan 21, 2016 | Singer 5400 Sew Mate 60-Stitch Sewing...
How do you replace bobbin
Usually, slide back the footplate, release the catch on the bobbin holder and lift it out.
the manual is available here at a cost
http://www.sewingpartsonline.com/instruction-manual-singer-5400.aspx
This one says it is available free
http://issuu.com/service-repair/docs/singer_5400_series_service_manual.pdf
Sep 23, 2015 | Singer 5400 Sew Mate 60-Stitch Sewing...
How do I fix the looping under the material when I sew?
the looping on the bottom usually is a tension problem, the top & bottom tension are unequal usually fixed by adjusting the top tension.
some people that I've talked with have had success with changing to a different size needle ( depends what type of thread is being used).
when the machine is threaded the foot needs to be up ( this releases tension on the thread), when the foot is lowered it the tension is set on the thread. if the material being sewed is too thick it raises the foot too high & releases tension on the thread ( the material has to be really thick to do this).
if there a piece of thread or lint in or around the tensioner or bobbin area it could cause trouble.
other wise if you've tried everything you can think of, take it back th the store & have them try it & tell you what is wrong.
also this machine has bad reviews (i'll provide a link so you can read them), people having the same problems as you are. the newer singers just don't seem to be the same quality tha the older ones were.
all bad reviews
http://www.amazon.com/Singer-5400-60-stitch-Sewing-Machine/product-reviews/B007ZG9DTQ/ref=cm_cr_pr_btm_link_1?ie=UTF8&showViewpoints=0&sortBy=byRankDescending
mixed reviews
http://reviews.walmart.com/1336/20573406/singer-5400-sew-mate-60-stitch-sewing-machine-5400-reviews/reviews.htm
Aug 26, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
I have a Singer Touch and sew 600e, the bobbin thread is all bunched up and machine jams up with thread. How can I fix this? Is there a simple setting that I am missing.
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly in the bobbin case
make sure the top thread is not coming off the thread take up lever
make sure the bobbin is wound correctly
if these suggestions don't work, I suggest that you take the machine
to a sewing machine shop to have it checked
Aug 06, 2012 | Singer Sewing Machines
C4 error code singer 5400 sew mate
I found out that I had to re thread and put the tension on the #5. That fixed it for me. Try that and see if it helps.
Jun 02, 2012 | Singer Sewing Machines
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
