Question about Cuisinart Blenders
Replace batteries in Cuisinart csb-78 - Cuisinart Blenders
Attachment stuck
try to rotate top part while you pushed it down with two hands, somme one must help you to handle basement with forces in oposite direction, work smoth dont give too much force in the samme time or you are going to broken top part, put force in ascending
May 10, 2014 | Cuisinart CSB-77 SmartStick Blender
What sort of step down transformer should I buy to use the cuisinart hand blender (US plug), in the UK?
http://lgcdn.220-electronics.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/5/0/500-watt-voltage-transformer-regulator-type4.jpg
It is actually a step-up transformer you need- from 120v to 220 v.
There are many of these transformers or converters listed on the web. Do a search " 120 v 60 hz to 220 v 60hz converter. "
The critical feature is to have a converter that has a wattage rating equal to or greater than the appliance that is plugged into the converter. It is best to a converter with a higher wattage rating than the appliance beacuse most appliances have a surge of current at initial startup.
May 05, 2014 | Cuisinart CSB-79 Smart Stick 2-Speed...
How to put motor and blade sections back together?
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
May 16, 2013 | Cuisinart CSB-33 Quick Prep Handheld...
My model csb 77 hit a bone and a plastic part in the motor assembly broke. Can I get it repaired? Can I take it apart and do it myself? Pete
No solution acording to the company. They do not sale this part..You'll have to buy the whole motor for 25$. I think they do that part on purpose to make you buy more. I have the same problem.
Jun 15, 2011 | Cuisinart CSB-77 SmartStick Blender
Blades not turning, motor spurtering
I would say that these high speed motors are prone to wearing out their brushes quite quickly, but are not really designed to come apart.
I suppose it is their mode of failure.
If you can find spare brushes for the motor, then do, but the unit is likely to be clipped and solvent welded together, so may be cracked during repair.
Feb 20, 2010 | Cuisinart CSB-77 SmartStick Blender
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
The handheld blender makes a horrible screeching noise all the time. I don't see anywhere to lubricate it or even take it apart. What's a person to do?
Time to use your warranty or throw it out. Not a serviceable product, you can't order a set of bearings for this. sorry
Aug 06, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
Blenders Logo
71 people viewed this question
Top Cuisinart Blenders Experts
eyecam
ray gallant
richie46
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
