Setup We bought a used viper 8012 a/c service station and it didn't come with a manual. How do you set up the hoses? The is high side, low side, vapor outlet, liquid inlet, heater, and a nameless connection on top side.
We bought a used viper 8012 a/c service station and it didn't come with a manual. does anybody have one ???
Posted on Jul 06, 2009
How and where to add freon to a1995 sedan deville
Verify ambient temperature is above 65 degrees F.
1. Safety> - safety glasses, long sleeves and gloves, (exposure to refrigerant can cause frostbite).
2. Attach hoses to manifold> assembly, (hi, lo, and fill).
3. Remove caps from service ports, (Low press. Larger tube from evaporator to accumulator - passenger side over fender well; High Pressure - smaller tube from evaporator along firewall towards driver's side). Verify service> ports are clean.
4. Attach low press. and high press hoses to proper service ports.
5. Start car>, reset low refrig code, and turn ac on high and fan on high.
6. Read gauges and compare with chart provided with gauge set.
7. If low and high press readings are both low, then system needs recharge.
8. To recharge, attach fill hose to can of R134a and slowly open low press valve>, (NOT HIGH PRESS VALVE), until low press side reads 40 psi.
9. When flow stops and pressures stabilize close valves> and disconnect manifold from service ports and refrigerant can. Replace service port caps.
Aug 19, 2015 | 1995 Cadillac DeVille
CHARGING THE AIR CONDITIONING SYSTEM Where is the valve to connect the refill cylinder?
not sure what you mean by refill cylinder, but there are two ports to charge a a/c system, low side and high side, you fill on the low side, if you are using a can you bought from wal mart or a auto parts store than most come with a small hose that connects from the can to the port, you cannot mess it up, the hose will only connect to the low side port, the high and low side ports are two different sizes, one is located on top of the engine by the suge tank area, the other is located/accessed from under the front right of the car, look for a big hose coming from the a/c compressor and just follow it till you find the port, the big hose is your low side hose.
Apr 04, 2010 | 1999 Ford Taurus
Have 134a refrigerant and shop where I bought it said owners manual will have the how to instructions. Unfortunately it doesn't. I see on the line there is a stem to screw the hose into but want to make...
No,you won't find it in the owner's manual. It charges through the low pressure side,which is the larger of the 2 available ports. You can't hook it up wrong. I suggest you buy a Hayne's manual for the truck. It has 90% of any answer you might need. A/C can be tricky to fix for the novice. If charging doesn't work,take it to the shop.
Jul 13, 2009 | 2001 Dodge Durango
Ac wont get cold after adding refrigerant
To diagnose problems, an A/C manifold gauge set is needed to read high and low side pressure readings. Avoid adding refrigerant with a simple charging kit like the ones sold at parts stores. Don’t add any stop leak, this can cause problems in the compressor, expansion valve or condenser.
Keep in mind that using an A/C gauge set and seeing BOTH high and low side readings can help in diagnosing the problem when you know what to look for. First, on a 134A system the high and low side service ports are different sizes. AC gauge sets have color coded hoses, the blue color coded hose has a connection that fits on the low side service port and the red hose has a connection that will only fit onto the high side. The yellow hose won’t hook up to anything if just checking the readings; it can be used to connect to a vacuum pump or attached to a refrigerant can or tank.
Normal readings on high and low side with AC OFF (static pressure) - Depends on outside temperature, but normally is between 80-105 PSI Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s - Ranges from 25-35 PSI - Note that on many Chrysler products a normal reading on the low side may be 15-25 PSI Normal high side reading ranges from 200-350 PSI.
Don’t assume that if adding little Freon is good that adding a lot is better!  Overcharging just a little can decrease the performance of the system and possibly damage the compressor.
Both low and high side readings are lower than normal, this indicates a cars AC system is low on refrigerant and is under-charged. If both low and high side readings are too high, this indicates an overcharged system - too much refrigerant. This also can indicate that the condenser fan is not working, is too slow or the car is overheating and heat is transferring from the radiator to the condenser.
When the low side goes so low that it’s reading shows it is in a vacuum, the most likely cause is a bad expansion valve or blocked orifice tube. Another possibility is a restricted condenser. Blocked condensers are not as common as they used to be but if a compressor fails and comes apart inside the remnants can end up in the condenser causing it to restrict the flow of refrigerant.
When the compressor clutch is definitely engaged and the low side is high and the high side is low, the most likely cause is that the compressor is failing - it is not pumping sufficiently. Rarely an AC clutch could be slipping but usually this will be accompanied with a squeal or chirp.
Hope this helps. If the compressor did come on and pulled the R134a in to the system, you may still be low or you may be over charged. With out any pressure readings it's had for me to say what is the problem. You could also have a bad orifice tube ( expansion valve) Good luck and hope this helps.
Jul 03, 2009 | 1998 Ford Windstar
I have full gas in my car but still no cold air inside the car
If you over charged the system your a/c will not work. To diagnose problems, an A/C manifold gauge set is needed to read high and low side pressure readings. Avoid adding refrigerant with a simple charging kit like the ones sold at parts stores. Don’t add any stop leak, this can cause problems in the compressor, expansion valve or condenser.
Normal readings on high and low side with AC OFF (static pressure) - Depends on outside temperature, but normally is between 80-105PSI  Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s - Ranges from 25-35 PSI - Note that on many Chrysler products a normal reading on the low side may be 15-25PSI  Normal high side reading ranges from 200-350 PSI
With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience. If normal gauge readings are obtained and the vent air is cold - STOP don’t overcharge the system. The only proper way to remove refrigerant is with a AC recovery machine so if this is being done at home I can’t emphasize enough not to over charge the system. And actually the best way to insure the proper charge is in a system, is to use an AC machine to recover the freon and then evacuate and recharge the system with the correct amount. Most cars have the specified amount on a decal under the hood.
Good luck and hope this helps, keep me posted be glad to answer any question you may have.
Jul 02, 2009 | 1998 Honda Prelude
How do I service my A/C 2000 Chevy Impala LS
If you are going to by the recharge kit at an Auto Parts store, With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience. If normal gauge readings are obtained and the vent air is cold - STOP don’t overcharge the system. The only proper way to remove refrigerant is with a AC recovery machine so if this is being done at home I can’t emphasize enough not to over charge the system. And actually the best way to insure the proper charge is in a system, is to use an AC machine to recover the freon and then evacuate and recharge the system with the correct amount. Most cars have the specified amount on a decal under the hood.
Good luck and keep me posted, be glad to answer more questions you may have.
Jul 02, 2009 | 2000 Chevrolet Impala
95 Deville - Low Refridgerant/AC Comp. off
Good luck and hope this helps, keep me posted be glad to answer any question you may have. And yes the A/C system on your car uses R143a and there is a A/C pressure switch along the low pressure line or on the accumulator, it looks like a oil pressure sensor with a two wire lead cliped on it.
Jul 02, 2009 | 1995 Cadillac DeVille
1997 Pontiac Grand Am SE High & Low Air Conditioner Service Valve
The connection at the evaporator is the low side and if you have 134A you cannot use r12 gage set.Get the 134A gage set!
Jun 24, 2009 | 1997 Pontiac Grand Am
1992 honda ex
The Freon goes into the "suction" hose/pipe assembly. There will be a service port on this hose. The low side (blue) hose of the manifold gauge set gets connected to this fitting. The suction hose can be identified by it's larger diameter (compared to the discharge and liquid hoses). The suction hose will run from the compressor across the top of the radiator (slightly behind the radiator), then back towards the firewall on the passenger's side of the engine compartment. The service port is generally closer to the firewall, than to the compressor.
Aug 31, 2008 | 1992 Honda Accord
Air Conditioning
#1 you will need r134a freon. #2 the low side service port is located right at the firewall where tha line goes to the evaporator. #3 if wou bought a can of 134a freon with a hose that will hook to it, it will work. all service fittings for 134a freon are the same even though the high side and the low side will always differ
Aug 18, 2008 | 1998 Oldsmobile Cutlass
Heating & Cooling Logo
124 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
