Question about V-Moda Headset VIBE in Gumetal Black Headphones
Sound very muffled in right ear bud
I was listening to my VIBE's on a very hot day about 2 months ago. When my ears started sweating the buds kept falling out, after I put the right one back in after it had fallen out, I could barely hear anything that came out of it. I let them sit for a while before trying again, and lo and behold the right ear bud is almost muted. I've checked the wires and everything I could without taking the grills off of the drivers and haven't found anything wrong with them. The warranty has long since been expired, so does anyone have any suggestions how to fix the problem?
  • 4 more comments
  • Anonymous Nov 12, 2007
    I've only had mine just over a month and my right bud is also muted!
  • paulenheimer Dec 02, 2007
    About a month ago I actually fixed my individual problem. It turns out I have real waxy ears (or so my doctor told me), and while running I guess the sweat washed it behind the screen in the right earbud. Using a staple I removed the little screen, and you could see what looked like a paste on the inside of it. I soaked it in some warm water and you could just see the wax come right off (a little gross). After that it worked fine, but I ended up losing the little screen because I removed the adhesive that held it on to the bud itself.
  • smrocknrolle Aug 25, 2008
    Im on my third pair. I mainly listen to audio books at low volume. I work out twice a day thus my modas are bombarded by sweat and ear wax. So i guess I should be able to rationalize why I have now spent 300$ on 3 pairs in the last 7 months. What a joke **** vmoda im never buying them again if they go public im shorting their stock. I will profit, as I imagine others share my POV.
  • artboyz Nov 18, 2008
    I had the same problem in the left ear. I removed the screen and it fixed the problem. Is there any reason to replace the screen?
  • Anonymous Dec 03, 2008
    Same issue. I'll give it a try!
  • chapilandia Apr 06, 2009
    ive also had mine for a while too. ide say a little over a year... maybe. and ive taken really good care of them except for a little accident wen i forgot to take them out of my pocket and my jeans got washed.
    they worked fine after they were dried... in the dryer... but about a month later the right ear bud lost its bass  and i took the little mesh thing off and there was nothing to clean so i dont know whats up with it.
Yes, more than likely it is the wax build-up inside the screen of the earbuds. Take a tack and lightly pry the screen out. You will definitely see a noticeable amound of "gunk on the inside. Clean and you will hear a clearer and crisper sound. If you put the screens on flush and press them in they will stay.
Posted on Sep 26, 2008
SOURCE:
My phones' audio jack won't play music from the right ear bud
Have you use another headphones insteading of your Sony headphones to have a try? Make sure it is not the problem of headphone, then you may need a headphone jack replacement to replace the old one.
I've also met this situation with my phone. Finally I found the right
Headphone Earphone Audio Jack Flex Cable for Samsung Galaxy S4 i9500 to solve this problem. You can also look for one repair part for your phone, then find a video following to fix. It is easy to make it. Hope it can help.
Mar 07, 2014 | Bose QuietComfort 2 Consumer Headphones
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Jan 22, 2014 | JVC Gumy Ear Bud Headphone - Peppermint...
Pontiac Vibe no cabin heat
The replacement thermostat may have failed.
Sep 13, 2012 | 2006 Pontiac Vibe
TOP END INTERMITTENT TICKING ON A 95 SPORTSTER 1200.
Hi Eric, I'm sorry but I loaned my listening ears to the lead technician at your local Harley Dealer so he could take your bike for a test ride and evaluate the noise. Have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 09, 2012 | Harley Davidson XL 1200 C Sportster Custom...
My right ear bud cuts out every time I move my head. I've only had this pair about six months.
It shows that there is a loose connection.
Take the item back to place of purchase and get a replacement. It should be under warranty.
Take care!
damnor01
May 28, 2011 | Bose in-ear headphones - Black with...
I have enjoyed my Bose headphones for a couple of years now and tonight I plugged them into my iPad to watch a movie and the sound from the right headphone diminished quite a bit compared to the left. I...
Could be possibly dirt in Ipad headphone jack (common prob) - put a drop of isopropyl alcohol in Ipad jack - just a drop. You might also check headphones in a computer jack to verify if it is possibly the headphones.
Apr 03, 2011 | Bose in-ear headphones - Black with...
One of the ear buds on me ifrogz earpollution headphones just stopped playing music. I haven't been dragging them around or getting them wet or anything, and they're only a couple of months old. The other...
I had same problem. 1 of earphones stopped working. If i turn up volume, some sounds gets through, but then the other earphone would be blasting. Used them running so maybe sweat or earwax clogged them, but the problem didn't start until 1 month after stopped running.
Mar 07, 2011 | ifrogz EarPollution Plugz Headphones
My right earbud stopped working and ive had the product for less than 2 months... all the wiring looks fine and no physical damage is noticeable
Unfortunately the ear buds are not made to be repaired, your best option is take them back for replacement "hopefully they are under warranty"
Mar 03, 2011 | Skull Candy LINK Earbuds Consumer...
I have the GC-1020 Element mp3 player..i have had it for 3 months.All of a sudden i can only hear the music out of one ear of my ear buds,i have tried my earbuds on something else and they work fine..why...
I have the GC-1020 Element mp3 player..i have had it for 2 months.All of a sudden i can only hear the music out of one ear of my ear buds,i have tried my earbuds on something else and they work fine..why won't sound come through both ears anymore?
Aug 22, 2010 | Sears GC-1020 MP3 Player
Open Questions:
V-Moda Headset VIBE in Gumetal Black Headphones Logo
7,130 people viewed this question
Top V-Moda Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
john h
Are you a V-Moda Audio Player and Recorder Expert? Answer questions, earn points and help others
