Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
I have a dyt 4000. It starts but then dies when I let out the clutch/brake. Is it the safety swith for when you press the clutch to start?
chad7houston
  • 62 Answers
SOURCE: replacing the blades on a craftsman dyt 4000
Not a hard job, but you will need a couple of tools. First, you will need a wrench that fits the nut that is holding the blade on. I prefer a closed end wrench, but an open end will do. Second, you will need a blade changing tool. The brand name is called a Blade Hog. It attaches to the deck and holds the blade in place so you can turn the nut. Raise the deck as high as it will go, attach the Blade Hog, and then loosen and remove the nut. Be sure and pay attention to which side is up on the old blade and put the new one on in the same manner.
hope this helps,
c
Posted on Oct 08, 2008
wadembly
  • 513 Answers
SOURCE: craftsman DYT 4000, 24 hp 48
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Posted on Jun 14, 2009
  • 127 Answers
SOURCE: My dyt 4000 Model # 917273620 won,t stay running
SAFTEY SWITCH IS MALFUNTIONING ON THE DECK OR UNDER THE SEAT
Posted on Jun 26, 2009
  • 138 Answers
SOURCE: riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Posted on Aug 17, 2009
mickey813
  • 472 Answers
SOURCE: I have the DYT 4000 model. My tractor will start
SOUNDS LIKE YOU HAVE ONE OF YOUR OTHER SWICHES ARE BAD LIKE THE SEAT
Posted on Sep 30, 2009
I think my bike is idled to high i put it 1sT AND IT DIES WHATS THE PROBLEM
Hi, Renee and the usual suspects are:
1. Faulty wiring to any safety switch.
2. Safety switches loose at the mounting point.
3. Faulty kickstand safety switch.
4. Failed kickstand safety switch circuit diode.
5. Stretched side stand spring.
6. Side stand not coming up far enough to disengage switch.
7. Faulty clutch lever safety switch.
8. Faulty neutral safety switch.
9. Clutch not properly adjusted.
10. Clutch plates sticking, forward lurch
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starts in neutral dies in gear
Stalls when put in first gear
XZ550 and XZ400 resources
OEM parts for Yamaha
Yamaha XZ 550 1982
Jul 11, 2012 | 1982 Yamaha XZ 550
When you let the clutch out or start the blades it dies
check the safety switches stat with the one on the clutch/brake pedal
Jun 02, 2012 | Craftsman YT 4000 42" Briggs Stratton 24...
Engine dies when the clutch is let out on riding mower
check the safety switch on the clutch/brake pedal
Apr 10, 2012 | Garden
Where is the part located that shuts the mower off when you release the clutch
There is a safety switch for the brake clutch and if the seat safety switch is not activated by someone sitting on it, then the mower will die. So if you are sitting in the seat and the brake clutch is released and the seat safety is faulty then the engine dies, so the seat safety is where you should start looking.
Aug 31, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Replace switches & clutch. When brake is release everything dies. Ineed a wiring diagram.
There are a few safety switches on a riding mower. One is the brake clutch, which must be engaged to start mower if not in neutral for a manual transaxle. Another is a blade engaged safety that will not allow you to start it with the blades engaged and the other is the seat safety that prevents starting if the brake is not engaged.
If the seat safety switch is messed up and you release the brake it will kill the engine. I would start there.
I hope this helps get you going.
Aug 03, 2011 | Garden
Craftsman DYT 4000 riding mower: Last year I notice the mower has lost some power. Going up hill and blowing the grass back to the bag catchers. I installed a new carburetor, magneto, fuel filter, higher...
your valves might be sticking due to old gas when you had some or the little rod clutch rod to the carb is disconnected this is just to choke it before it dies out.
I sugest that you clean out the carb out with carb cleaner and also clean the valves.
Mar 29, 2010 | Water Heaters
Mower blades engages but when I stop to empty grass they will not
yes it is there is one under the seat & under the dash & there is also one connected to the clutch/ brake peddle which is more than likely the one giving you problems is the clutch/brake peddle switch
Jun 22, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
13 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
