Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony TV I have a problem with my 32" Sony TV blinking on an off. When the picture comes on it is so clear, but then the black screen, then the picture, then the black screen. It has been doing this for a week now
  • Bouldergolf Dec 15, 2007
    I have Sony Trinitron KV32FS12 and when the set warms up the screen goes to black but sound stays on. Ity does it more during commercials then a show. Annoying. I have checked the cables and it is straight line to cable so no mid-line interfearance. Good cable wires (COX Provided). All other sets in home fine.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Your problem is due to video or luminance section. remember it is loose contact only in that section or print loose. please check 1 crt base loose 2 supply line loose contact. 3 loose contact near chroma signal processor in luminance section only. 4 any connector loose. 5 no component failure.
Posted on Sep 25, 2007
SOURCE:
My Sony 32" TV with CCFL Back-light module started having green tint. On black colored images, green pixels are clearly visible.
according to your observation we called abnormal picture & common mode choke coils are defective l3000,whech are near to LVDS connecter there are 3 coils & must change all coils after replacing these coils your set will ok
Jul 10, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking a black screen on and off.
Picture tubes do not "go out" by going black: Your TV has a power heat-related issue. It is trying to come on but, the protection circuit is preventing it.
As; opening it to dust it, is dangerous; I suggest you take it to a good tv shop.
May 19, 2009 | Televison & Video
My tv blinks from regular picture to a black screen continuously.
your tv is on the blink.
remove the back panel of set
on the crt pcb board you will find a wite or black pot.
turn it up or down while set is on this is the [email protected] voltage ajustment.
you might get 3 monts to a year of extra life from your pictor tube by doing this.
regards,
daniel.
Dec 23, 2008 | Sony KV-32S42 32" TV
Blinking STANDBY Light front of Television
Hii...
Refere to Sony Blinking Codes :
5 Blinks ===> cause AKB circuit (AKB). Something is wrong with the video. check components on the C board, also check the A board. Also unit be in IK blanking, try turning up screen slightly.
Hope can solved the problem....
[Vrya]
e-mail : [email protected]
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My TV will not turn on!
I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
Dec 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv35s66: No picture, just sound and red blinking
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Aug 05, 2007 | Sony KV-32S42 32" TV
My tv blinks from black screen to picture
You might have loose conections on the horizontal driver or output circuit,do not use it like that or it will go dead completely and is going to cost a lot more.If the set is older than 5 years it might have loose conections in the power supply too.Call someone qualified for an estimate.
Sep 13, 2006 | Sony KV-32S42 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
129 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
