Get them ready for summer
I would like to know if there is anything that I need to do to get my aircondtioner ready for summer.
    President:
  • 1,489 Answers
Make sure there are no weeds around the outside compressor.
See that all vents/louvers are clear.
Change air filter inside if it hasn't just been changed.
Clean algae off cooling fins -- be careful with these -- they are very fragile and can be easily damaged -- you can get a kit from an appliance parts store to clean them
- check all pipes, insulation, etc. for damage -- repair as needed
Turn it on
Posted on Apr 23, 2009
Where is thebeeper in the airconditoner as it beeps whens the aircondtioner is off.
Wow! Three rapid posts. When you post for the fourth time, PLEASE specify the make and model of your air conditioner.
Nov 10, 2016 | Heating & Cooling
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
Vacuum hose diagram
NEED MORE INFO POSSIBLE DIAGRAM ON HOOD OR RAD SUPPORT GM IS VERY GOOD FOR THIS UNLESS SOMEONE REMOVED IT.
Jun 08, 2013 | 1998 Buick LeSabre
No speedo replaced stator and rect last summer
Hi. It will be the sensor on the front wheel, it may need a clean but be very careful as it is very fragile. If it is broken then just superglue it up and put back in carefully. Hope this helps
Mar 12, 2013 | 2002 Triumph Daytona 955i
How often do i need to replace my fuel filter?
SIMPLE MAINT SCHEDULE , IS CHANGING IT ONCE A YEAR, but it depends where you live, If this truck is a diesel & you live in a northern climate, change your filter once a year but not until you know for ceretain that you are buying winter grade fuel, ie: nov
Reason for this is that there will be wax/parafin build up in the filter that your ran on the summer fuel, it can congeal in the filter in winter becasue of this build up. If you replace the filter in late autumn, then tat filter will not have a congeal problem because the there hasnt been anything but winter grade fuel through it, , and its safe to run all next summer , but the summers residue will cause problems next winter , so change again in late autumn .
Sep 27, 2010 | 2001 Dodge Ram 2500 Truck
Icing of the fins of my lg aircondtioner indoor unit
Check/clean intake air filter and condenser fins,as well as be sure condensation drain is clear as well. Sometimes if not the right angle, moisture remains inside unit rather than draining outside, or wherever your drain is, make sure it's clear and draining well.
Feb 03, 2010 | LG Electronic Window Air Conditioner
How to clean and store for summer
need it it will be ready, flush water system with clean water with a dash of bleach mixed in. The bleach will inhibit any mildew or moldClean fan of collected dirt, remove and replace filters so when you needed again it will be ready..make sure all water is drained and let unit thoroughly dry outdoors. Good luck
May 07, 2009 | Honeywell International QuietCare...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
