Question about Bontrager DuoTrap Digital Speed/Cadence Sensor
I just bought and installed a Bontrager Duotrap sensor with a Node 2 computer. I programed the computer, put new batteries in both sensor and computer, but I still do not get a speed reading from either the sensor or the spoke magnet.
Bontrager trip 300 is not connecting.
Disconect battery for one hour , then re-try .
Feb 12, 2015 | Computers & Internet
Bontrager node1.1 computer
Sounds like one of two things: the head unit needs to pair up with the sensor again; or the battery in the sensor is dead. Here is a manual in PDF form for the process of setting up the computer: http://media.bontrager.com/owners_manuals/computers/Bontrager_Node_1.1_+_2.1_EN.pdf
Mar 27, 2014 | Cycling
I bought a 98 vw jetta glx vr6 2.8 it has been parked for 2 years untouched due too previous owner installing ignition coil wrong and short circuiting it. once i bought it i installed the ignition coil...
Try depressing gas pedal halfway. If that helps it start, then check out the engine coolant temp sensor. If the sensor is off or corroded, the computer won't feed enuf gas.
Jun 29, 2017 | Volkswagen Jetta Cars & Trucks
Kodak cx6330 will not transfer pics to computer
1) Go to My Computer > Select the photo camera device > Right click > Explore > Copy all files (photographs) as from any normal folder.
2) Take out your SD memory card, put it the USB card reader: http://www.amazon.com/b?ie=UTF8&node=516872 If you have a modern laptop - it will have a special card reader slot. Go to My Computer > Select the SD card > Right click > Explore > Copy all files (photographs) as from any normal folder.
3) Try Picasa (picasa.google.com), install, run and import pictures with this program.
Mar 05, 2011 | Kodak CX6330 Digital Camera
Sir, I have eight Hallmark card programs. I love it! I make my grandkids a card a week and put a dollar in it! My problem is,my computer is very slow. My husband bought me a new one..7 I have had an XP...
This program has been designed to work exclusively in XP - so it will not install in 7.
You have 2 options:
1. you ask a friend to install in your new pc the XP mode
http://www.microsoft.com/windows/virtual-pc/download.aspx
and in it you install your Hallmark program.
2. you just reinstall XP in the old pc and no other program but Hallmark and the printer - it will run as fast as when you bought it.
Nov 24, 2010 | Computers & Internet
Hi my 06 BMW 325i the battery went dead on my car...
When inside your car is it a the IBS (intelligent batery sensor) what this is the all recharging controlls. Battery must a registrated to car memory when new is where after change to empty battery! In diagnostical tools only! Car remember so how a old empty battery and recharging no good!
WARNING: Use you AGM specially batterie with fibre glass for your BMW attached only!
May 20, 2010 | 2006 BMW 3 Series
Only 2 injectors are firing
More than likely your injectors are burnt out. You need a digital multimeter to check it out. Unplug the connectors to the injector. Check the resistance it should be around 12 ohms. If the measurement is much higher it is burnt out out. Using a node light, If you don't have a node light you can use a LED with a 1k resistor connected to the anode. Connect that to the injectors wire terminals to see if the computer is providing pulse to it. Caution don't put DC current on injectors by using the battery, you will damaged them. Don't use a regular light bulb to see if the computer is providing pulse, it can damage the computer. The LED light must have a 1k resistor in series with it. This makes it safe to connect to injector terminal.
Jun 28, 2009 | 1996 Dodge Neon
I want circularlinklist program in c++
This C++ program is to perform the following operations
on a circular linked list
1)insertion
2)forward traversal
3)reverse traversal
4)search
->node structure :
a node contains
1) integer data
2) pointer to next node
-> This program works in microsoft VC++ environment
in windows xp
-> This program uses the following header files
1)iostream.h
#include<iostream.h>
class cll
private:
int data;
cll *next;
public:
cll* insert_one(int,cll*);
cll* delete_one(int,cll*);
void ftraverse(cll*);
void rtraverse(cll*);
void search(int,cll*);
void function();
cll*hd;
void cll::function()
cout<<”******************************************\n”;
cout<<”program to implement a circular linked list \n”;
cll * head;
head=NULL;
cout<<”\n\nMENU :\n”;
cout<<”1)insertion\n”
<<”2forward traversal\n”
<<”3)reverse traversal\n”
<<”4)search\n”
<<”5)exit\n\n”;
cout<<”Enter your option :”;
int opt;
cin>>opt;
int d;
while(opt!=5)
switch(opt)
case 1:
cout<<”Enter data to the node :”;
cin>>d;
head=insert_one(d,head);
cout<<”inserted\n”;
break;
case 2:
cout<<”The forward traversal is :\n”;
ftraverse(head);
break;
case 3:
cout<<”The reverse traversal is :\n”;
hd=head;
rtraverse(head);
cout<<”NULL\n”;
break;
case 4:
cout<<”Enter the element to be searched :”;
int d;
cin>>d;
search(d,head);
break;
case 5:
break;
default:
cout<<”invalid option”;
break;
<<”2)forward traversal\n”
<<”4)search\n”
<<”5)exit\n\n”;
cin>>opt;
cll* cll::insert_one(int d,cll* c)
cll*NEW;
NEW=new cll;
NEW->data=d;
NEW->next=NULL;
if(c==NULL)
c=NEW;
c->next=c;
else
cll*c1=c;
while(c1->next!=c)
c1=c1->next;
c1->next=NEW;
NEW->next=c;
return c;
void cll::ftraverse(cll* c)
if(c==NULL)
cout<<”\nlist empty\n”;
return;
else
cll *c1=c;
cout<<c1->data<<”->”;
c1=c1->next;
while(c1!=c)
c1=c1->next;
cout<<”NULL\n”;
void cll::rtraverse(cll* c)
if(c->next==hd)
cout<<c->data<<”->”;
return;
else
rtraverse(c->next);
void cll::search(int d,cll* c)
cll*c1=c;
if(c==NULL)
return;
else
if(c->data == d)
cout<<”found\n”;
return ;
while(c->next !=c1)
if(c->data==d)
cout<<”found\n”;
return ;
c=c->next;
if(c->data ==d)
cout<<”found\n”;
return ;
cout<<” search unsuccess ful \n”;
void main()
cll list;
list.function();
Mar 05, 2009 | Computers & Internet
Half life 2 node graph out of date
Kernel and registry drivers for that program could've gotten bumped by another program or just jammed.
try running a registry repair program on it and see if that will do the trick.
Nov 08, 2008 | Computers & Internet
Bontrager DuoTrap Digital Speed/Cadence Sensor Logo
54 people viewed this question
Top Bontrager Cycling Experts
Ted Maxwell
dante
Donald Ayers-Marsh
Are you a Bontrager Cycling Expert? Answer questions, earn points and help others
