My Vaio laptop boots up fine, but the monitor is dark and illuminates when I wiggle the lid a bit. I'm worried that it will get worse. Any advice please? Lee
    Problem Solver:
  • 6 Answers
Check you Warrenty information and Return it to the store/Sony Center. this is a disaster wating to get bigger
Posted on Apr 23, 2009
My dell inspirion 6000 laptop screen goes black but sometimes I can see the windows screen but it's very dark. When I attach it to a desktop monitor it works fine but the laptop is still dark. Sometime the...
The back light is the whole of the screen, the screen is illuminated by a CCFL lamp (fluro tube) on the bottom of the screen. A inverter supplies high voltage to this CCFL lamp.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 08, 2011 | Computers & Internet
Acer laptop will not boot up
Dead (ish) Laptop.
Press the power button momentarily to check if it is hibernating or in stand by. If this doesn't work;
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine and the laptop still won't start, then you may have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Feb 04, 2011 | Acer Aspire 5610-4648 Notebook
Why doesnt my laptop turn on ??
Dead Laptop.
Hope this helps.
Nov 22, 2010 | Computers & Internet
Power button blinking, no display light.
Dead/ish Laptop.
If the adaptor is fine and the laptop still won't start, then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Nov 16, 2010 | Acer Computers & Internet
The laptop would not boot up. It was hooked up to an external screen and then a few hours later, there was nothing on the screen. It wont boot up into a POST screen
Dead Laptop?
If the adaptor is fine then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Nov 09, 2010 | Acer TravelMate® C314XMi (G16012) Tablet...
Screen goes dark
It could be the display power inverter or the illuminator is going out. generally the inverter goes first.
Apr 29, 2010 | Sony VAIO PCG-K33P Notebook
My sony Vaio lap top monitor just went dark...I could see everything if I used a flashlight...this lasted about 20 minutes...I did a recovery ...nothing happened..just now it lit back up . I dont...
When then laptop boots up but the screen is dark then most likely it is a back-light problem. Please click on this link and follow my instructions to determine the fault and possible fix :-
Jan 22, 2010 | Sony VAIO VGN-NR430E/S NoteBook
Laptop screen goes dark after booting .
your issue with your laptop is a faulty ccfl BackLight Inverter, the display uses the backlight to illuminate the lcd screen, the inverter is used to illuminate the cold cathode light in the back of ther lcd theirs countless places to laern about it on google.
They are cheap to replace google your model with inverter at the end..
They are not too hard to replace
Nov 21, 2008 | Dell Latitude CP (0001849d-38380-968-p06e)...
Compaq presario 2200 screen stay dark
sounds like the inverter has gone, the only way to test this is to remove the laptop lid, remove the bezel (front plastic cover) please take care not to crack or splitt the plastics, then get an electical tester and test the inverter coil to make sure a current runs through it, if it doesn't its the coil, if it does you need a new inverter, the coil is located under the plastic sheath
good luck
Nov 14, 2008 | HP Compaq Presario 2200 Notebook
Screen/ video display is dark.
Sounds like a backlight or inverter problem or both. Most likely the backlight in the display panel. Unless you know how to open your laptop and if needed the and the display panel I would take it in to a professional. If you are able to do it yourself you can make sure that everything is plugged in properly. And test the components inside. You can replace these parts which are not very expensive. But if you have not be inside a laptop I would take it into a local shop for repair.
Sep 12, 2007 | HP Compaq nx7010 Notebook
Open Questions:
Norton antivirus chat Number~-1*888*866*2O82 Norton internet security phone number, Norton Technical support Phone Number Norton antivirus chat Number~ 1*888*866*2O82 Norton internet security phone number, Norton Technical support Phone Number Norton Support Number/ 1*888*866*2O82 Norton Technical support Phone Number Norton Support Number/ 1*888*866*2O82 Norton Technical support Phone Number Norton help desk number, Norton internet security phone number, Norton internet security customer SUPPORT Norton internet security customer SUPPORT phone number Norton internet security help phone number Norton internet security phone number customer SUPPORT Norton phone number customer SUPPORT Norton phone number customer support Norton phone number Norton phone number Norton customer service Norton support phone number Norton customer service phone number Norton support Norton contact Norton technical support phone number contact Norton Norton contact number Norton customer support phone number Norton customer service number phone number for Norton support number Norton number Norton technical support number Norton telephone number Norton technical support phone number for Norton customer service Norton helpline number Norton phone support Norton help desk phone number. Norton 1800 number Norton phone telephone number for Norton telephone number for Norton customer service contact Norton customer service phone number Norton help phone number Norton customer care number Norton telephone number customer service Norton helpline number for Norton contact Norton by phone Norton phone number support phone number Norton customer service number for Norton Norton customer care phone number Norton online phone number Norton customer service Norton customer service telephone number Norton support telephone number Norton customer care Norton help number Norton australia renew Norton Norton problems Norton customer service helpline number Norton contact details Norton for phone contact Norton customer service Norton renewal Norton account call Norton customer service online Norton Norton help desk Norton help desk number www Norton antivirus, Norton 360 support number Norton customer phone number Norton 360 phone number Norton mobile technical support for Norton Norton technical support telephone number Norton removal tool Norton install how to install Norton Norton 360 customer service phone number Norton for mobile Norton USA+ 1*888*866*2O82 Norton toll free number Norton troubleshooting Norton sale reinstall Norton Norton phone number customer service us Norton customer service phone number. Norton Support Number 1*888*866*2O82 Norton Technical support Phone Number.
May 21, 2018 | Norton Computers & Internet
Norton 1*888*866*2O82 Norton support number @ Norton support phone number !!!!!!!! Virus removal tool@Norton contact +1 *888*866*2O82 Norton Support Phone Number Norton Technical Support Number Norton Tech Support Number Norton antivirus customer service Norton technical support phone number Norton customer service support Norton customer service email address Norton customer service reviews contact Norton customer service Norton tech support number usa Norton antivirus contact number Norton technical support usa Norton technical support number Norton tech support phone Norton antivirus support number Norton antivirus support phone number Norton Antivirus phone number Norton Antivirus Customer Service Number Norton Antivirus Customer Service phone number Norton Antivirus Customer Support Number Norton Antivirus Customer Support phone number Norton Antivirus customer care number Norton Antivirus toll free number Norton technical support phone number for Norton customer service Norton helpline number Norton phone support Norton help desk phone number. Norton 1800 number Norton phone telephone number for Norton telephone number for Norton customer service contact Norton customer service phone number Norton help phone number Norton customer care number Norton telephone number customer service Norton helpline number for Norton contact Norton by phone Norton phone number support phone number Norton customer service number for Norton Norton customer care phone number Norton online phone number Norton customer service Norton customer service telephone number Norton support telephone number Norton customer care Norton help number Norton australia renew Norton Norton problems Norton customer service helpline number Norton contact details Norton for phone contact Norton customer service Norton renewal Norton account call Norton customer service online Norton Norton help desk Norton help desk number www Norton antivirus, Norton 360 support number Norton customer phone number Norton 360 phone number Norton mobile technical support for Norton Norton technical support telephone number Norton removal tool Norton install how to install Norton Norton 360 customer service phone number Norton for mobile Norton USA+ 1*888*866*2O82 Norton toll free number Norton troubleshooting Norton sale reinstall Norton Norton phone number customer service us Norton customer service phone number. install Norton ANtivirus~ +1 *888*866*2O82~ Norton Technical support Phone Number.
Contact Us: -l*888*866*2O82 Norton support phone number Norton antivirus technical support phone numberNorton Phone Number?? Norton ANTIVIRUS Tech Support Number l*888*866*2O82 Phone Number for Norton Technical Support Norton Antivirus Technical Support Phone Number Norton support number Norton antivirus phone number Norton antivirus number Norton customer support number Norton customer service number Norton customer care number Norton antivirus phone number Norton antivirus support number Norton phone number Norton customer support phone number Norton customer service phone number Norton customer care phone number Norton antivirus tech support phone number Norton antivirus technical support phone number Norton antivirus phone number Norton antivirus support number Norton phone number Norton customer support phone number Norton customer service phone number Norton customer care phone number Norton 36O support number Norton Antivirus customer service number Norton Antivirus 36O support number Norton customer service phone number Norton internet security support number Norton Antivirus support number Norton internet security support number Contact Webroot Antivirus support Norton Antivirus phone number Norton Antivirus online support Norton customer service number Norton technical support phone number, Norton technical support number, Norton number, Norton help phone number, Norton help number. Norton help desk number, Norton help desk phone number, Norton tech care number, Norton tech care phone number, Norton tech support telephone number, Norton technical support telephone number, Norton phone number, Norton not working, Norton troubleshooting phone number, Norton troubleshooting support number Norton tech support, Norton tech support number, Norton tech support number usa, Norton customer service chat, Norton internet security customer service phone number, Norton number I- l*888*866*2O82 Norton phone number, Norton technical support phone number l*888*866*2O82.Norton Tech Support Number Norton Tech Norton tech support, Norton tech support number, Norton tech support phone number, Norton technical support, Norton technical support number, Norton technical support phone number, Norton tech support number, Norton support number, Norton Tech support phone number, Norton tech Support phone number Norton Support phone number I-888-866-2O82 Norton Support phone number l*888*866*2O82 USA, Norton Tech Support phone numbeR.
May 21, 2018 | Webroot Computers & Internet
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
