Question about Gbc HeatSeal H425 Laminator
Paper jam H520 gbc heat seal laminator - Gbc HeatSeal H425 Laminator
3 Suggested Answers
  • 5603 Answers
SOURCE: GBC Heat Seal H525 -
The problem would either be UNEVEN pressure of the rollers from one side to the other OR the roller sets are NOT parallel. The cogs should have NOTHING to do with it.
Posted on Sep 15, 2011
m4c2
SOURCE: a laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Posted on Jun 30, 2012
Testimonial: "Thanks! It's all fixed now and put back together!"
The laminating paper started coming out rippled half way through a roll. Do you have any suggestions?
Usually caused by uneven pressure / heat. If this has a lot of use look near ends see if you have small ridge that goes around roll. Would be where edge of paper would be. If you do your pressure roll is worn and no longer provides constant pressure feed.
replace rollers.
Sep 23, 2016 | Gbc HeatSeal Ultima 65 Roll Laminator
Why doesn't our laminator always roll?
It sounds like the control panel switch membrane( under the panel buttons) needs to be replaced. The bad sound may be your heat roller bearings failing. They dry out and start squealing. They also can cause your machine too slow down or stop. There are 2 bearings on either side of the laminator, 4 total.
Sep 08, 2015 | Gbc Heat Seal Ultima 65 Laminator 1710740
Does the GBC Ultima 65 have an adjustable pot to increase heat of rollers? If so, where is it located?
Ordinarily, laminators have speed controls to allow the laminated substrate to get hotter.
Feb 12, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Laminate did not come out it just went back inside on roller
warm the machine back up, get the glue sticky again, then work it off, either by going in forward or reverse, whichever works best for the given situation. Don't use anything sharp as the rollers damage easily....very expensive
Sep 09, 2014 | Gbc Heat Seal Ultima 65 Laminator 1710740
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
A laminate and paper jam in a Gbc HeatSeal H425 Laminator
floating cowboy
Jun 26, 2012 | Gbc HeatSeal H425 Laminator
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Gbc HeatSeal H425 Laminator Logo
57 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
