Question about Canon i860 InkJet Photo Printer
Printer won't turn on
I have a canon I860. Yesterday it worked perfectly, today it won't turn on. there is a small buzzing sound from the back of the printer when its plugged in, barely noticeable, but i get nothing from it. any ideas?
  • Anonymous May 05, 2009
    Just doesn't turn on anymore. Worked fine one moment, the next there was a failure trying to print and the diagnostics window said "Error Number : 5200 A problem has occurred with the printer mechanism. Cancel printing and turn off the printer. Wait a few moments, then turn the power back on. If the problem persists, contact one of the service centers."
    After that it never turned on anymore
Sounds like power supply is cooked.
Posted on Apr 24, 2009
Ink spots on back of printed page from Canon i860. What to do?
Type in your search engine How to get rid of ink spots on back of printed page from Canon i860 printer.
It will take you to How to download a manual that will help you fix this issue. PDF.
Jun 18, 2017 | Canon i860 InkJet Photo Printer
Printer quit printer will not come on
i560 Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 28, 2010 | Canon BubbleJet i560 InkJet Printer
One of the colors, yellow, on my canon i860 will not print
The Canon i860 holds the cartridges in an ink carrier.
Remove all of the cartridges, making note of the order that they go into the carrier.
Squeeze the sides of the carrier and lift it out.
Place a small amount of rubbing alcohol in a glass dish and dip the bottom only of the carrier into the dish.
Repeat this and see the old ink flow away from the carrier.
Blot the carrier on a paper towel by lifting and pressing it against the towel.
Once it is dry and clean, place it back into the printer and replace the cartridges.
While you are replacing the cartridges, look to see that they have liquid ink in the right side of the cartirsge. If not, replace that cartridge.
Jan 22, 2010 | Canon i860 InkJet Photo Printer
My canon ip4000 was working perfectly until yesterday. Suddenly it won't print the correct colors. Sometimes the nozzle check looks perfect, sometimes some colors are low, sometimes colors are mixed...
It could be a few different things but letys try the easiest first. Go into control pane/jprinters/ and do a deep nozzel cleaning. leave the printer idle for about a hour or two before trying to print again. You may have to repleat this procedure. If this does not fix your problem it could mean that you need to update a driver for your printer or that you have changed your colour settings in a graphic program such as adobe. Failing all else you may just need brand new cartridges. I have a canon i860 and found a very inexpensive site online to order the cartridges for a few dollars each. even if you don't need the cartridges right now check out the site and stock up.
http://www.piloshop.ca/index.php?main_page=advanced_search_result&search_in_description=1&keyword=canon+i+series+cartridges
Jan 09, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Canon i860 printer not working
The error code says that your printhead is bad and needs to be replaced. QY6-0049-000 around $40.00
Jun 30, 2009 | Office Equipment & Supplies
Large black ink tank is not being used by the printer.
The little cartridges are pigment for photo printing. The Large black cart is ink for plain paper (usually text) printing. If you select a photo paper in the print setup menu, you will use very little of the ink.
To check the function of the large cart print out a test sheet from the printer maintenance menu. You may need to run a head cleaning to get all the nozzles to work.
May 11, 2009 | Canon i860 InkJet Photo Printer
Photo print quality Canon i860
You might be running low on toner or ink. In this case check out the ink/toner capacity left. it might even be a faulty cartridge if bought new, or a faulty printer, but it doesn't sound like it.
Dec 27, 2008 | Canon i860 InkJet Photo Printer
Canon i860 error codes
Try this: With your i860 printer turned ON, press and hold the I/O switch then pull off the power cord. This will turn off your printer. But without lifting your finger on the I/O switch put back your power cord. the I/O switch will blink for a second and will go off, then turn-on your printer again and see if it works.
Sep 15, 2008 | Canon i860 InkJet Photo Printer
Waste ink tank full
normally, the logical solution is to replace your waste ink tank, but I have tried a solution which could make your canon printer function again.
Try this: With your printer turned ON, press and hold the I/O switch then pull off the power cord. This will turn off your printer. But without lifting your finger on the I/O switch put back your power cord. the I/O switch will blink for a second and will go off, then turn-on your printer again and see if it works.
Aug 26, 2008 | Canon i860 InkJet Photo Printer
Canon i860
Have a look at the yellow cartridge. I have had trouble with inks leaking into each other...most noticeable in the yellow. I have no solution...perhaps the printhead is a piece of ****...works well when it works.
Mar 12, 2008 | Canon i860 InkJet Photo Printer
Canon i860 InkJet Photo Printer Logo
282 people viewed this question
old marine
old marine
