Question about E-Book Systems FlipAlbum Standard
Key code. 1045-1085-4328-3250-0779-4665 - E-Book Systems FlipAlbum Standard
Request specific code or codes to program the RCA Universal Remote RCRN03BR to operate JVC DVD/VCR type HR-XVC33U. The codes provided in the remotes instructions provide only partial functionality on the...
Found some quick solutions including the manual for you
first here is the link for hte code list and manual http://www.rcaaudiovideo.com/remotes/2-3-devices/?sku=RCRN03BR
which i got from various sites after researching your problem for about 30 minutes please let me know if this works i hope i helped i tried really hard
if that doesnt work try these methods PLEASE LET ME KNOW IF I HELPED
for this first method you need the direct code which is 04
  1. Manually turn on the component you want the remote to control.
  2. Locate the Brand Codes in the Code Lists.
  3. Press and hold the component key you wish to program. The illuminated ON·OFF key turns on and remains on.
  4. While holding the component key down, press and hold the ON·OFF key. The illuminated ON·OFF key turns off.
  5. After holding both keys down for three seconds, the illuminated ON·OFF key turns back on.
  6. Release both keys. The illuminated ON·OFF key remains on.
  7. Refer to the Brand Codes. Press and release the appropriate brand code key (Numbers 0-9), using the number keys. The illuminated ON·OFF key blinks once.
    • Note: If you do not press a valid Brand Code Search key, the illuminated ON·OFF key blinks four times and turns off. The last programmed code under that component key is retained.
  8. Press and release the ON·OFF key repeatedly until your component turns off. Each time you press the ON·OFF key, the illuminated ON·OFF key blinks, and the next code is sent. The Brand Code Search begins with the first code in the chosen brand list for that component and cycles through all the codes for that brand. If your component turns off, you have found the correct code. (If it cycles through and the illuminated ON·OFF key blinks four times and turns off, all codes in the chosen brand list have been searched and another programming method should be tried. The Brand Code Search mode is exited.)
  9. Once you have found the correct code, save that code by pressing and releasing the STOP key. The illuminated ON·OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
  10. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your component do not work, program the remote with a different programming method.
if not try this for auto code search
STEP :
  2. Press and hold the component key you wish to program. The illuminated ON·OFF key turns on and remains on.
  3. While holding the component key down, press and hold the ON·OFF key. The illuminated ON·OFF key turns off.
  4. After holding down both keys for three seconds, the illuminated ON·OFF key turns back on.
  5. Release both keys. The illuminated ON·OFF key remains on.
  6. Note: If you press an invalid key during Auto Code Search, the illuminated ON·OFF key blinks four times and turns off. The last programmed code under that component key is retained.
  7. Press and release the PLAY key, then wait five seconds to see if your component turns off. If your component does not respond, continue to press the PLAY key every five seconds until your component turns off. Each time you press the PLAY key, the illuminated ON·OFF key blinks ten times and a block
    of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. (If your component has not turned off after all codes have been searched, the illuminated ON·OFF key blinks four times and turns off. The Auto Code Search Entry method is exited.)
  8. When your component turns off, you know the correct code is in the last block of 10 codes sent. Press and release the REVERSE key. Wait two seconds to see if your component turns on again. If your component does not respond, continue to press the REVERSE key every two seconds until your component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE key is pressed, the illuminated ON·OFF key blinks.
    • Note: If you accidentally press the REVERSE key after your component responds, press and release the FORWARD key. Then, wait two seconds to see if your component turns off again.
  9. Once your component turns on, you have found the correct code. Save the new code by pressing and releasing the STOP key. The illuminated ON·OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
  10. When you press the STOP key, the code is stored.
Mar 16, 2011 | RCA RCRN03BR Remote Control
Codes???
Here you go....
EX C&W KEYS -- KEYROLL 23/12/2008
PROVIDER CODE: 5C 01
KEY 00 = D8 53 39 BD 3D CA 86 C1
KEY 01 = EF 38 DF 11 3D 85 FE 2F
TELEWEST KEYS -- KEYROLL 23/12/2008
PROVIDER CODE: 5A 01
KEY 00 = E7 D3 69 2E 6F 38 EA 78
KEY 01 = E8 C9 E5 6E B0 49 53 F5
PURE NTL KEYS (UK) -- KEYROLL 23/12/2008
PROVIDER CODE: 54 01
KEY 00 = 7F CD 76 82 BB 22 0A C5
KEY 01 = 97 9B 22 E0 5B 13 B1 C7
IRELAND CHORUS KEYS -- KEYROLL 18/12/2008
PROVIDER CODE: 5E 01
KEY 00 = CE 19 2E 87 80 61 74 90
KEY 01 = 62 FA D9 F3 CE 05 FA 79
IRELAND NTL KEYS -- KEYROLL 18/12/2008
KEY 00 = B0 B8 4F 04 E6 5F 87 80
KEY 01 = A3 EB EC 07 D6 49 D2 EB
MERRY XMAS!
Dec 24, 2008 | StarTech.com StarView SV211K 2-port KVM...
Codes for my eurovox
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 04/12/2008
KEY 00 = D4 A3 5D EB 7B F3 69 59
KEY 01 = 27 77 A1 FC 8F 9D 34 76
TELEWEST KEYS -- KEYROLL 04/12/2008
KEY 00 = C0 F6 61 87 91 F9 67 57
KEY 01 = F0 83 35 E5 28 40 49 B2
PURE NTL KEYS (UK) -- KEYROLL 04/12/2008
KEY 00 = 3F B8 36 62 72 E5 E2 76
KEY 01 = 35 5E D6 40 6E AA 99 41
IRELAND CHORUS KEYS -- KEYROLL 29/06/2008
KEY 00 = 51 0F 32 A7 D9 34 BE 3E
KEY 01 = 8D A3 88 1B 4E 32 C5 8F
IRELAND NTL KEYS -- KEYROLL 18/06/2008
KEY 00 = 75 92 B1 CC 6F 23 20 F1
KEY 01 = F2 46 B1 59 04 61 77 71
KEYS BROUGHT TO YOU BY
DE-CRYPT.NET AND THE CHATTERBOX.CC TOOLBAR
Dec 07, 2008 | Televison & Video
Eurovox codes foe cw please 3 december
EX C&W KEYS -- KEYROLL 02/12/2008
KEY 00 = 2F 1E 90 1B EA 7F A0 26
KEY 01 = 01 54 B4 A5 79 46 CD AA
TELEWEST KEYS -- KEYROLL 03/12/2008
KEY 00 = 3F 32 37 03 D0 73 84 84
PURE NTL KEYS (UK) -- KEYROLL 03/12/2008
KEY 01 = DB 7A A2 F2 4B 12 7E 59
Latests Codes from 3rd of december
Dec 03, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes 54 01 needed for 2/11/2008
Make sure u get the rite NTL codes
These codes are from the 4th of December. nt the 2nd as u reuested. have changed sinc :)
Dec 02, 2008 | Euro-Pro 534DX Mechanical Sewing Machine
Code for501a area
EX C&W KEYS -- KEYROLL 30/11/2008
KEY 01 = 60 1F 48 73 19 D6 CA 99
TELEWEST KEYS -- KEYROLL 30/11/2008
KEY 01 = C6 64 1D EF 47 5A 0E EF
PURE NTL KEYS (UK) -- KEYROLL 30/11/2008
KEY 00 = 5A 35 D6 3B 4D A0 75 EC
KEY 01 = 28 98 21 38 22 BC B9 EF
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview codes
new codes for 30/11/08
KEY 00 = 98 37 0A 2E 85 61 E0 9A
KEY 01 = 90 24 A0 00 CB FA 36 27
KEY 00 = B7 19 92 E2 9B 15 AF 96
KEY 01 = 3C 12 5C 17 D4 3F 7E 64
KEY 00 = C1 65 E8 D4 B4 74 C4 FD
KEY 01 = F5 E5 DC A4 14 7F FF 41
Euro-vox digibox codes
EX C&W KEYS -- KEYROLL 29/11/2008
KEY 00 = 00 58 8D CF 27 98 04 ED
KEY 01 = 2A E0 72 B0 9E 07 9B 5D
TELEWEST KEYS -- KEYROLL 29/11/2008
KEY 00 = 98 B0 BA 52 D3 21 08 B4
KEY 01 = D2 EA 29 B7 B5 52 E9 AD
PURE NTL KEYS (UK) -- KEYROLL 29/11/2008
KEY 00 = CD 11 58 05 EE 96 E7 F3
KEY 01 = EA B7 BF B2 D5 AA 46 AB
Nov 30, 2008 | E-Machines eMachines Desktop PC
Eurovox codes
Nov 30, 2008 | Televison & Video
Eurovox maxv codes in bradford thanx
Nov 28, 2008 | StarTech.com StarView SV211K 2-port KVM...
Computers & Internet Logo
Top E-Book Systems Computers & Internet Experts
David Payne
David Payne
Are you an E-Book Systems Computer and Internet Expert? Answer questions, earn points and help others
