Question about Garden
Husky 3650 model number Hu3650b will not produce power but runs
  • 7,482 Answers
Hi Jordan c
Sounds like you have dirt/debris in your caburetor jets, fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Bud
Posted on Oct 11, 2013
What kind of oil?
It actually depends on the environment but you will be okay with 10W30
Mar 27, 2016 | Husky 3650 Watt Generator with Subaru...
Does the husky 3650 have a fuse on it because the motor runs great but im not getting power.
No, there is no fuse. The problem is most likely the capacitor. Do you have the model number on the motor
Jul 19, 2013 | Air Tools & Compressors
I am needing a manual for an 18: Husqvarna chainsaw. Serial Number 3490744. Need to know what type of oil, etc. to use in it. Thanks
We cannot answer without a model number. You can find what you seek here (if a model 18 it very old; please use the second link):
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Husky recommends 50:1 today (last 15 years ±)
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jun 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Using way to much oil
This is a Husky 455 Operator's Manual (May 2009)
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-95.pdf
Page 37 explains the oiler adjustment. CAUTION: is has only 3 positions, forcing it to far CW or CCW will damage your saw. Against the CW stop is the minimum oil position.
You can find the correct manuals here:
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
HTH
Lou
Jan 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Oiler adjustment screw missing . Can see some sort of smooth goged rotor which spins when engine running but apears to be nothing connectted to it to action oiler. Cant access a parts list to see whats...
If Husky try this for IPL:
HusqvarnaUSA.com
06 1500198
Repost with model and serial numbers and I can provide more guidance. HTH
Lou
Jan 10, 2010 | Husqvarna Garden
Husqvarna 372 xp gas tank not venting has a new gas cap did not work
I looked at a 2007 IPL, your saw has a separate fuel tank vent. Husky is terrible about providing a nomenclature and you may need help from your local Husky dealer to identify components.
Find your "Illustrated parts lists" here:
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
HTH
Lou
Nov 14, 2009 | Husqvarna Chain Saw 20" Bar
Throttle lock is broken. Wow do I repair it
Get an estimate from your friendly neighborhood Husky dealer. You might be pleasantly surprised at how reasonable they are.
An IPL (exploded parts list) with handle detail can probably be found here:
HusqvarnaUSA.com
06 1500198
HTH
Lou
Oct 31, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hi how to put front spring in to clutch brake
No model 61 listed @ Husqvarna.
How about a 261 here:
HusqvarnaUSA.com
Enter 261 (no XPs, Es, just the numbers)
06 1500198
See the Chain Brake Assembly detail. HTH
Lou
Oct 22, 2009 | Husqvarna Chain Saw 20" Bar
Ive just bought a husqvarna 34 husky is this the model number 34? its serial number is 016810 but i cannot find details of it anywhere an want a manual can you tell me mixture also its my first chainsaw,...
Get Chain lube for the chain oiler. Naturally, husqvarna recommends that you use "genuine husqvarna" oil for your mixture, I recommend a quality oil, doesn't have to be husky. Husqvarna recommends a 50:1 ratio, other manufacturers, of vertually all 2 cycle power equiptment use a 40:1 ratio. This mixture is slightly richer, but will not hurt your chainsaw. May produce a bit more smoke. Not sure what a 34 husky is...neither is Husqvarna, I visited the website and even tried to download a manual. Looked at every husky model, no 34.
Jun 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
