Question about Aurora Electronics AS890C Shredder
I took the head apart to un jam it. Can't figure out where to put the sensor that turns it on?
Says jam inside but no jam how do I reset it I tired un plugging it but it still says jam I took it apart and no Jam not even a spec of paper
BEST OPTION GO TO STORE FROM WHERE YOU BROUGHT IT. DONT TRY FIXING THE PROB YOURSELF YOU MAY TURN UP SPOILING IT MORE
Dec 26, 2012 | Brother MFC 7840W Printer
J'ai un ricoh mp 1600 apres un bourage j'ai un message d'ereur sc 559 comment faire
The exit sensor and
the duplex sensor
detect a paper jam 3
times in succession
Paper jams can occur for the following
reasons.
???? Dampness
???? Paper curl
???? Incorrect paper setting in the paper
tray
???? Stripper pawls coming apart
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
I TOOK APART A BROTHER MFC-3240C PRINTER AND CLEANED THE HEAD NOW IT KEEPS SAYING PAPER JAM PUT THERE IS NO JAM.WHERE IS THE PAPER JAM SENSOR LOCATED AT
well have you cleaned the head manually or by using the software thru the pc. if you have done so by hand it may cause aproblem try cleaning using the software and see id that helps.
Oct 03, 2010 | Brother MFC-3240C All-In-One InkJet...
Back boor wont open
I opened the back pannal and un-bolted the lock base from the body den took lock apart and made a new 1 useing parts i had from my old suit case yes i said suit case i used the locking pin from that 2 replace the broken 1 on the door
Sep 30, 2009 | 2005 Renault 18I
Printer says carriage jam, but I cannot see what the problem is.
I had a "carriage jam" error message.
My son gently wiped down the metalic strip that tells the carriage where it is. It worked for a couple of days and then the "carriage jam" message came back.
I took my 7210 apart, took the drive belt off/put it back on (not easy), and found nothing wrong with it. So, I put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
I had the same problem with my DVD player. The head was hanging up on the two chrome plated rods that supported the head. I put some 3-in-one oil on the rods, ran the head back and forth, and it has worked ever since.
You might also check the belt to make sure that there is nothing that might cause it to hang-up.
Kevin
Nov 29, 2008 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
Hi...
Try to move the carriage maually left and right ..still does not work...service the printer.
Regards
debroy
Nov 25, 2008 | HP Officejet 7210 All-In-One InkJet...
Hp officejet 7210 allin one,carriage jam,tried all hp troubleshooting
Kevin
Nov 24, 2008 | HP Officejet 7210 All-In-One InkJet...
Print carriage jammed
My son wiped down the metalic strip that tells the carriage where it is. It worked for a couple of days and then the "carriage jam" message came back.
I took my 7210 apart, found nothing wrong with it and put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
Kevin
Oct 12, 2008 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
Kevin
Aug 13, 2008 | HP Officejet 7210 All-In-One InkJet...
Carriage jam
I had a "carriage jam" error message. I took my 7210 apart, found nothing wrong with it and put it back together. I noticed that if I pushed the print carriage all the way to the left, closed the lid, and pressed "OK", the print carriage would move a couple of inches to the right. It did this repeatedly. I figured the motor was working, but there was too much friction on the carriage. I put some 3-in-one oil on my finger and put a thin coat on the front, top, and back of the rod that the print carriage rides on. I then ran the carriage back and forth about 20 times. I closed the lid and it works fine.
Kevin
Jul 19, 2008 | HP Officejet 7210 All-In-One InkJet...
Aurora Electronics AS890C Shredder Logo
74 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
