Question about NEC Electra Elite DTU 16D-2 Corded Phone
The red light on my NEC phone wont stop blinking
I have an NEC phone Model: ip1na-12txh tel (bk). Its a 22B HF/DISP ASPIREPHONE-BK. S/N 17104828F2. When I was in another room cleaning the phone the intercom went on and now the front desk light wont stop flashing. I have called for tech support and they gave me a do not disturb and a message code that didn't work. Do you know any other codes that I can try?
3 Suggested Answers
SOURCE: I need to know how to use the caller id
Why is the Metro Suburban Recovery Learning Community such a messed up organization?
Posted on Apr 25, 2010
SOURCE: nec 22b hf/disp aspirephone-bk
1. have the first call on the line (do NOT put on hold), (call 1 or 2)
2. press CONF key
3. dial 9 for an outside line and dial the number
4. press CONF **twice** to join calls.
Posted on Jul 24, 2009
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
Nec 12txd phone not ringing and led indicator not working.
the only other setting that could turn the led off is if you enable blocking mode and you check disable led indicator (found by long pressing blocking mode in the pull down window). do you have any apps that could control the led lights like light manager? if so, try uninstalling it or checking its settings. if you dont have an apps like that, have you tried installing one to see if it works?
Feb 24, 2014 | NEC Aspire 22 Button Ip1na-12txh 0890043...
How do I set up the call divert on our NEC DT300 Series phone so that all incoming calls are diverted to another land line? The info on the back of the phone is - NEC DT 300 Series DTL-24D-1A(BK) TEL...
I am not sure which country you are in, but in Australia your divert depends on your phone carrier not your model. If your carrier and call plan supports call forward you just dial their set number and follow the prompts to turn on or off.
Oct 22, 2013 | NEC Lands Phones
Phone won't ring
while the phone is hung up, press #725. Then press any line button that isn't solid green until it is. You just have to cycle to "Always"
Apr 05, 2013 | NEC Dsx 22b Display Tel bk Dx7na-22btxh...
How do I change the day & date on the NEC aspire system
i have a 22B HF/Disp Aspirephone today I came in and the date is wrong how do I change
Mar 14, 2011 | Lands Phones
I need to know how to use the caller id on the NEC Aspirephone Model IP1NA-12TXH Tel (BK)
i need to know how tosee my call and delete then fron the phone
Aug 24, 2009 | Lands Phones
NEC 22B HF/Disp Aspirephone
http://www.askemergent.com/downloads/aspire-phone-qrg.pdf
http://www.askemergent.com/downloads/aspire-phone-feature-guide.pdf
Dec 26, 2008 | Radio Communications
Nec 22b hf/disp aspirephone-bk
2. press CONF key
Nov 10, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
4,570 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
