Hp pavilion dm1 - I got this laptop and the boot screen said some thing about hd failure so I grabbed an old hd from my old hp laptop. Now that I placed the hd start up repair cant fix it . What do I do now?
SOURCE: HP Pavilion dv1000
i have the same problem here.. i re-install windows, home premium to Xp pro sp2, and my note book model is Hp dv1000, i downloaded driver from hp site but it does't help... i can't even connect to internet.. i think i need the whole driver.. sounds did't work, and even the quick play bottom... can any one help me. thank you
Posted on May 15, 2008
I found out how to fix the no sound problem on The HP Pavilion DV1000 Look under Dv1310 thats the model number the driver your looking for is SP30262.exe
Posted on Jun 07, 2008
mailtoravi
  • 186 Answers
SOURCE: HP Pavilion dv900 problem
Issues related to Motherboard may cause booting issues.
HP needs the Noebook to be available at any Service Center to examin it.
If the Notebook was purchased in US, they will send you a box through FedEx so that you can ship your Notebook in that.
Notebook will be returned within 7 to 9 days after repairs.
Unfortunately, if you are currently out of US, then the situation is critical as not all the service centers will be able to repair the Notebooks avaiable in all locations.
Posted on Aug 11, 2008
SOURCE: HP laptop not booting up - blank screen
hi
I had the same problem faced twice in one month, and it’s a new laptop just one month old,
I have removed battery for for few minutes and fixed it back. And it's working fine now.
If it continues what should I do?
Posted on Nov 02, 2008
joecoolvette
  • 5660 Answers
SOURCE: My HP pavilion g7 laptop's screen is gone dark,
Primer first, jhb4954;
An LCD screen cannot produce light. It needs an additional light source.
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
A Backlight is the additional light source.
A Backlight can be a CCFL or a series of LED lights.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size of a CCFL is 2mm Thick, and Length is almost as long as the LCD screen is high. { 2mm is a little more than 1/16th of an Inch.
.0625 = 1/16th of an Inch. .0787 = 2mm )
A screen Inverter is used to convert the power (Electricity) from the laptop, for the LCD screen, and Backlight.
A small circuit board approximately 3/8ths of an Inch in Height, and 3 Inches in Length. (Varies as to screen Inverter model )
Located behind the Display Panel Bezel, and mounted at the bottom of the LCD screen.
Usually mounted with one Philips head screw, and has two cables going to it.
Video Cable, and cable to the Backlight.
(Plastic thin frame in front of LCD screen, and resembles a picture frame, is the Display Panel Bezel. HP's name.
The LCD screen is the Display Panel )
Primer over.
The HP Pavilion G7's series came out with EITHER using
CCFL, OR LED lights for backlighting.
Just depends on what model number it is.
[ HP = Manufacturer
Pavilion = Model Line
G7 = Model Series
In the white Service Tag located on the bottom of the laptop, is P/N.
This = Product Number
HP's model number ]
1) NOT all LED backlit LCD screens use a screen Inverter.
2) a screen Inverter is the problem 90 PERCENT OF THE TIME.
Which leads us to several options;
Option 1:
Your Pavilion G7 LCD screen uses a CCFL for backlighting.
It also uses an Inverter. (screen Inverter)
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
A relatively inexpensive part. It is also MUCH more easily accessed, than trying to replace the Backlight. (And much cheaper than replacing the LCD screen)
Test a screen Inverter? Requires a sensitive multimeter. Read - fairly expensive,
http://www.fonerbooks.com/test.htm
Because of the low cost, ease of accessing to replace, and lack of proper test equipment, most users at the consumer level just replace the screen Inverter.
A parts changer type of repair granted, but when viewing the alternatives this may be the only viable solution.
[ Note*
An LCD screen and a screen Inverter are a MATCHED UNIT.
When replacing the screen Inverter make SURE you get the proper one]
Screen Inverter replacement doesn't repair the problem?
Then the decision is made whether to attempt replacing;
A) The CCFL, (Or CCFL's { 2 }, if the model uses it ),
Or,
B) Replacing the LCD screen as a unit.
The CCFL is a Fluorescent bulb. Means it has Mercury inside.
It is also VERY thin in Width. Means it can be broken easily.
It is also more difficult to access;
Primer:
An LCD screen is composed of layers. This can be seen in the first link I posted.
These layers are kept together in a specific pattern, by the Screen Frame. (Left to Right, Top to Bottom, as well as the layer's order )
A thin metal frame which surrounds the LCD layers.
[ Two styles of Screen Frame used, to my knowledge;
1) Two piece. One Top part, and one Bottom part. Resembles two picture frames put together, but they each have a lip like a cake pan.
One slips inside the other.
Small countersunk head screws hold the two parts together.
2) Four piece.
Top, Bottom, and two Side pieces. Uses countersunk head screws also)
The CCFL is usually on one side, and right under one of the Screen Frame frame rails, (Unless a dual CCFL model. One on each side ),
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
{ Note* Sometimes a CCFL is not offered separately from the LCD screen, by looking up it up with the laptop model number. In this case a match is made, by using any identifying manufacturer product codes on the bulb ]
Option 2:
Your Pavilion G7 uses an LCD screen with LED backlighting,
AND it uses a screen Inverter.
Suggest replace the Inverter first.
Then if this does not fix the problem, replace the expensive LCD screen.
Option 3:
Your Pavilion G7 uses an LCD screen with LED backlighting. Does Not use a screen Inverter.
Replace the LCD screen is the only option.
Several HP Pavilion G7 LCD screen models. Some with CCFL, some with LED,
http://www.screenaid.com/hp-laptop-lcd-screens-pavilion-dv7-series-c-1204_16810.html
This is HP Support > HP Pavilion G7-1075DX Notebook PC > Manuals download page,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=5093430&
Left-click on the first file listed, for a free Service Manual, for the
HP Pavilion G7 series of Notebook PC's.
(I just picked a model number to access the Service Manual, for the entire model series. Just from my experience )
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds, before the first page comes up.
(Took 10 seconds using medium speed DSL connection, just now)
If you wish post the Product Number in a Comment, and I will guide you in replacing.
Regards,
joecoolvette
Posted on Apr 18, 2012
Hp dv9800 service manual
1) http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Scroll down to the subheading - HP Pavilion dm1. (dm1 in blue)
Go down to the second line in this 'paragraph', and scroll across.
Click on the blue dv9000.
After you click on the file name (9000) it may take up to 30 seconds, before the first page comes up.
2) http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-hp-pavilion-dv9000-laptop/
3) http://www.cesgeekbook.com/2010/01/dv9000-disassembly-tear-down-part-1.html
4) http://www.youtube.com/watch?v=bnkQNmKauEc
Not advertising, using for reference material.
Regards,
joecoolvette
Aug 22, 2012 | HP dv9819wm Notebook, 17.0 WXGA+...
Removing back cover of hp dv 6915nr
Back Cover?
1) Display Cover: The plastic cover that is on the opposite side of the LCD screen. Sometimes referred to as Top Cover.
Display Assembly is removed from laptop first, then LCD screen assembly is removed from the Display Cover.
2) Base Enclosure: The plastic bottom part of the notebook.
A laptop is disassembled from the Top down to the Bottom.
The bottom 'cover' (Base Enclosure) is not removed first. It is last.
3) There is no back cover per se. Half of the cover for the back (Bottom half) is part of the Base Enclosure. The top half is part of the Palm Rest.
(The back has the Vent in it)
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
[Use the dv6700 service manual. Go down to the subheading HP Pavilion dm1 (dm1 is in blue)
Scroll to the right, click on dv6700. Note that it is a PDF file, and may take up to 30 seconds, before you see the first page come up ]
What is it you are trying to do? What hardware component are you trying to access?
Post back in a Comment.
Regards,
joecoolvette
Display assembly is removed. Palm Rest Cover is removed, and so on.
Jan 14, 2012 | HP Pavilion dv6915nr Notebook
I need a manual for HP DM1-4027S A
HP Ireland Support > Pavilion DM1-4027sa Notebook PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=5177008&lc=en&cc=ie&dlc=en&lang=en&cc=ie
Click on - Manuals - in the right column.
In the list;
HP Pavilion dm1 Entertainment PC - Maintenance and Service Guide,
is a Service Manual. (Free)
It is a PDF file. After you click, it may take up to 30 seconds before the first page comes up.
HP Notebook Reference Guide - Windows Vista and Windows 7,
is a User Manual.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 29, 2011 | HEWLETT-PACKARD Computers & Internet
Need a replacment or new motherbord for tx1410us
1) http://www.sparepartswarehouse.com/HP,Pavilion,tx1400,KC469UA,Laptop,System-Boards.aspx
2) http://www.pelltechnology.com/HP-Parts/HP-Pavilion-Laptop-Parts/HP-Pavilion-TX1000-Series/HP-Pavilion-tx1400-series/HP-Pavilion-tx1410us/Motherboards-%26-LCD-Screens/
The Pavilion tx1410us Notebook PC is one of the Pavilion tx1000 series of Notebook PC's.
Here is the download page for a free Service Manual,
Go to the 18th line down. The line that starts with HP Pavilion dm1.
Go to the second line and across to tx1000.
Left-click on tx1000.
This is a PDF file. You may not see anything happening for up to 30 seconds after you click.
The file is downloading in the background.
After you see the first page it may take additional time for the file to fully download.
Suggest you let the file download all the way before looking through it.
Nov 25, 2010 | HP Pavilion tx1410us Tablet PC
How to re-install bluetooth on my hp pavilion dm1?
Since you only put dm1, go to this page and pick exactly which one of the 107 different models of dm1 you own and click on it. At the Drivers page, select the proper operating system (xp/vista/w7) you are using and you'll be shifted to the complete list of drivers for your computer.
You want to download the "bluetooth stack/software,driver (whatever...lol)" for your laptop and install it.
Regards,
TheSelkie
Jul 21, 2010 | HP Computers & Internet
Display and Boot problem with HP Pavilion DV2125NR
It is normal for the bottom to get hot. The fan should keep it cool enough to run, but it sounds like perhaps your fan is not working very well anymore and should be replaced.
Does the computer act up at all when cool? If not, the first thing I would try is replacing the fan and examining the fan and heatsink assembly for proper installation, perhaps replace the heatsink compound with some Arctic Silver while you have it open.
Jul 10, 2009 | HP Pavilion dv2000t Notebook
HP dv1000 Laptop Locks Up
It maybe bad sectors on hd but first Id defrag disk see if any improvement
Jan 23, 2009 | HP Pavilion dv1000 Notebook
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
