Question about Linea Italia LITTR737OAT - Trento Line L-Shaped Desk, 59-1/8w x 59-1/8d x 29-1/2h, Oatmeal"
Holes in the top panel and return of a Linea Italia LIT-TR737 Corner Desk do not match up with the frame. Instructions were poorly written, but I believe that my assembly matches the diagram included with the packaging.
Ikea Leksvik desk. I'm on step 16 of 20 but the screws aren't working. The inner screws are not securing the wooden frame to the table top. Has anyone else come across this problem?
Did you match up the screws with the chart in the manuel. You may have the wrong screws and used the appropriate screws in another part of the desk. Make sure by checking the screw chart on the manuel and see if that helps.
Feb 20, 2011 | Office Equipment & Supplies
Got some running boards for a tuscon, have not got a clue how to fit them as the instructions are very vague. Any one ever fitted some?
Depends on what manufacturer, assemble them loosely and hold them up in place , holes should match holes on the frame, you will find they only go on one way
May 17, 2010 | 2005 Hyundai Tucson
Basket will not center unless pushed
The tub is held at center by springs. A spring may be broken. Parts and an exploded view of your machine are available at www.sears.com , Model number is usually located at the back of the lid opening and looks like 000.000000 , I have instructions for outer case removal for new and old Kenmore2_bing.gif top load. Instructions are as follows: Disconnect the power cord. There is either two screws, one at each front corner, holding the control panel in place or hidden clips. 1. If you see the two screws remove them. If no screws are visible you have a clip at each front corner of the control panel. The best tool to use to unhook these clips is a putty knife. Push the putty knife between the machine top and the control panel from the front at either outer corner. You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring releases the corner will lift easily. Repeat at the other corner. 2. Now, if there was two screws holding the panel, remove the two screws at the top on the back of the control panel. If just clips, simply and carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Make needed repair and reassemble reversing procedure. Allow 30 to 45 minutes for the first removal. Good luck.
Jan 23, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore 80 series,wont agitates or spin and make a grinding noise when I try.I need some help,Im not sure whay part to order.
Between the motor and the gearbox there is a three piece device called a coupler. It has two parts with three fingers and a rubber piece with six holes. The fingered pieces fit one on the gearbox and one on the motor. The rubber piece fits between and acts as a shock absorber to soften the impact of the motor's sudden start on the gearbox. This coupler is the weak link and it does wear out and may be your machine's problem. You must either tip the machine back far enough to see if it is bad or remove the outer case. The closest piece to the front will be the water pump then motor then coupler. If you choose to remove the case here are instructions.
Disconnect the power cord. Turn off the water. There is either two screws, one at each front corner, holding the control panel in place or hidden clips. 1. If you see the two screws remove them. If no screws are visible you have a clip at each front corner of the control panel. The best tool to use to unhook these clips is a putty knife. From the front push the putty knife between the machine top and the control panel at either outer corner of the control panel . You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring releases the control panel corner will lift easily. Repeat at the other corner. 2. Now, if there was two screws holding the panel, remove the two screws at the top on the back of the control panel. If just clips, simply and carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the front of the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Make needed repair and reassemble reversing procedure. Allow 30 to 45 minutes for the first removal. Good luck.
An exploded view of your machine is available at www.sears.com under the parts direct tab enter your model number, found under the lid at the back of the tub opening. aka. 000.00000
Sep 18, 2009 | Washing Machines
I want to disassemble to clean around the top of the basket. How do I disassemble this washer?
These instructions are for Kenmore top load machines. Disconnect the power cord. There is either two screws, one at each front corner, holding the control panel in place or hidden clips. 1. If you see the two screws remove them. If no screws are visible you have a clip at each front corner of the control panel. The best tool to use to unhook these clips is a putty knife. Push the putty knife between the machine top and the front of the control panel at either outer corner. You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring releases the control panel corner will lift easily. Repeat at the other corner. 2. Now, if there was two screws holding the panel, remove the two screws at the top on the back of the control panel. If just clips, simply and carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the case top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Make needed repair and reassemble reversing procedure. Allow 30 to 45 minutes for the first removal. Good luck.
Sep 13, 2009 | Kenmore Washing Machines
Bad vibration, then something ssnapped and a piece came off, heard it in there
The tub is held at center by springs. A spring has probably broken. Parts and an exploded view of your machine are available at www.sears.com , Model number is located at the back of the lid opening and looks like 000.000000 , I have instructions for outer case removal for new and old Kenmore top load. Instructions are as follows: Disconnect the power cord. There is either two screws, one at each front corner, holding the control panel in place or hidden clips. 1. If you see the two screws remove them. If no screws are visible you have a clip at each front corner of the control panel. The best tool to use to unhook these clips is a putty knife. Push the putty knife between the machine top and the control panel from the front at either outer corner. You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring releases the corner will lift easily. Repeat at the other corner. 2. Now, if there was two screws holding the panel, remove the two screws at the top on the back of the control panel. If just clips, simply and carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Make needed repair and reassemble reversing procedure. Allow 30 to 45 minutes for the first removal. Good luck.
Aug 24, 2009 | Washing Machines
Wahing machine is not spinning or rotating at all.
Between the motor and the gearbox there is a three piece device called a coupler. It has two parts with three fingers and a rubber piece with six holes. The fingered pieces fit one on the gearbox and one on the motor. The rubber piece fits between and acts as a shock absorber to soften the impact of the motors sudden start on the gearbox. This coupler is the weak link and it does wear out. You must either tip the machine back far enough to see if it is bad or remove the outer case. The closest piece to the front will be the water pump then motor then coupler. If you choose to remove the case here are instructions.
Disconnect the power cord. There is either two screws, one at each front corner, holding the control panel in place or hidden clips. 1. If you see the two screws remove them. If no screws are visible you have a clip at each front corner of the control panel. The best tool to use to unhook these clips is a putty knife. Push the putty knife between the machine top and the control panel at either outer corner. You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring releases the corner will lift easily. Repeat at the other corner. 2. Now, if there was two screws holding the panel, remove the two screws at the top on the back of the control panel. If just clips, simply and carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Make needed repair and reassemble reversing procedure. Allow 30 to 45 minutes for the first removal. Good luck.
An exploded view of your machine is available at www.sears.com under the parts direct tab.
Aug 23, 2009 | Washing Machines
Need info on how to remove driver side door panel. I'm trying to install a new electric window assembly on a 02 Dodge Caravan Thank You Dave
I can give you generic info on how door panels are fastened and removed. I hope this helps. The outer perimeter of the panel is held in place on the sides and bottom by push-in fasteners that match holes in the door frame. These fasteners have button heads that attach to the back side of the panel, and the have ribbed shafts which are pushed in to the door frame holes. There are screws and/or bolts that secure the door arm rest and door handle molding to the frame. In some designs the screw head are concealed by small buttons, or by a piece of molding plate that pops out.
First step is to locate and remove all these screws. Next step is to place a screw driver at the edge of the door panel, between the panel and door frame and pry the panel away from the frame. There is a trim tool that is made for this task (relatively inexpensive) that you can purchase at the local auto parts store. The sides and bottom of the panel are popped away from the frame. After sides and bottom are loose, the top is released by pushing up to release the upper window molding from the frame. Be careful of wiring on the back side of the panel (electric windows, locks, etc.) Unplug all electric before you remove the panel totally.
Those nylon fasteners tend to break when the panel is removed, but they are replaceable (again, at your auto store). Just take one with you to match it up.
I hope this helps you!
Jul 25, 2009 | Dodge Caravan Cars & Trucks
Top loading #110.29842990 Outer shell came
The outer case catches under the frame across the front and there is a tab on either side on the frame near the back these tabs go into a slot in the flange on the bottom of the case. You may need to loosen the control console to do this. 1. Disconnect the power. 2. Remove two screws, one at each top corner on rear of console. 3. Push a putty knife under the front of the console near the corner. You will feel the resistance from a spring steel clip. Push, firmly toward rear of machine. clip will release and console will be loose. Repeat at other front corner of console. 4. make sure outer case is hooked under front of frame. 5. Put case on both tabs(check at rear corners on back of machine to assure that back panel and case corner are in the modling that aligns the two. This is sometimes like a wrestling match. Take your time it can be a test of your patience. It is helpful to see diagrams available at www.sears.com under Parts direct. Find your model number and an exploded view is available. Good luck.
Jun 30, 2009 | Kenmore Washing Machines
Linea Italia LITTR737OAT - Trento Line L-Shaped Desk, 59-1/8w x 59-1/8d x 29-1/2h, Oatmeal" Logo
35 people viewed this question
Top Linea Italia Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Linea Italia Furniture Expert? Answer questions, earn points and help others
