Freezes up During Backups
I have a Mac Power PC G4 running OSX 10.4.11. I also have a LaCie firewire external HD design by F.A.Porsche 250GB which I have had for some time now. My LaCie drive keeps freezing up when I try to backup something to it. I run Quickbooks for my business and used to make regular backups to the LaCie HD. I installed Carbon Copy Cloner to make a backup of my Mac HD to my LaCie HD but it froze up during the process. I have tried using disk utility erase tab (zero out data) and the partition tab to reformat the LaCie HD. After doing so same problem. It use to work fine. I noticed the problem when I bought my daughter a new laptop and transferred all her stuff from my Mac to the LaCie HD then to her computer. What I did wrong though was once downloaded to the LaCie HD I just unplugged the firewire from my computer and plugged it into her new laptop without unmounting the LaCie HD. This seems to be when all the problems started. Any HELP? Thanks, Jeff Paquette
    Scholar:
  • 65 Answers
I suggest an application called "Disk Warrior" it has always maintained high ratings among us Mac enthusiasts it has a hardware test function built into it and seems to be a little better at verify and repair functions than Disk Utilities which you can try also if you haven't yet. You may also consider trying a different firewire cable if you have one handy. Other than that a reformat should have put the disk back into an original state however the disk could have been damaged by not un-mounting it in rare mac cases. If you have the time you can also reformat the disk again although I would try the first two options first.
Posted on Apr 26, 2009
Cannot detect LaCie mini hub HD.
Try a new power supply. $19.99 at Lacie. It worked for me.
Dec 20, 2009 | LaCie Computers & Internet
FW Lacie Porsche FW ext. HD 250GB light on case blinks and
conect your harddisk to computer whch has windows xp.
Then go to start emnu then type in run 'cmd"
then you can see command propmt.
Then go to your external drive letter like f:
then type 'chkdsk /r"
then pres "y'
then it fix error on hardisk.
Aslo you can format it .
Just take backup of data which you need then right clik on drive licon and format it.then it works fine.
Jun 23, 2009 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Macintosh computer not recognizing the LaCie external hard drive
1. If you have another firewire device test this device with the same firewire cord you are currently useing for the LaCie. (if there is no reasponse form the other device then it is the cord it's self) If not then 2. Check the Leads on the back of the LaCie where the firewire plugs in if the copper looks tarnished use a ear swab dipped in Lime Away or CLR to clean it then wait for it to dry and try the cord again. 3. if these physical connections are in good connection with each other and the firewire in port on your computer and on the LaCie are good then. Run a "Permissions" verify and repair through the disk utility program on your Mac with the LaCie turned on and plugged in.
FINALLY if none of these options repair the LaCie you may have to open the LaCie up and check to make sure the soldering from the firewire to the chip set is still in tact. I hope this helps Happy Macing.
Mar 28, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie RUGGED 250GB not recognized by my PC
I think the migration assistant (in the utilities file in your application folder) can transfer files direct via USB.
Jan 23, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Recognized - but no mount
Don't know about the MAC part, but an I/O error implies that the either the source file cannot be read or the destination drive will not write. This is usually an indicator of a bad HDD. To check, I would attempt to connect the external drive to another computer. If it still gives the same indication, contact the drive manufacturer about data recovery recommendations
May 29, 2008 | LaCie (300728U) 250 GB Hard Drive
Lacie 250GB changes date when copied
Unfortunately, when you copy a file, you are technically creating a new file hence it would assign the current day's date as the new date.
Jan 14, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Computers & Internet Logo
432 people viewed this question
David Payne
David Payne
