Question about Sunterra 3000 GPH Pond Pump 203000
Need replacement pump for Stonebrook Falls fountain
Why would my pump be humming very loudly?
It might have some worn parts inside, like the bearings, or bushes
May 26, 2016 | PW Cal Pump 4500 Waterfall Pond Pump 2010...
Pump for old willies dilemma fountain by Henri studio
There are a lot of non submersible pump which are available in the market however, a submersible pump would offer you less trouble of piping connections and maintenance.
Sep 11, 2013 | Henri Studios Henri Studio Wee Willie's...
I need a replacement pump with lights for lion head fountain
need replacement lights for ion head fountain.
can't replace bulb. Rubber is brittle and broken.
need complete bulb and wire to transformer connection.
where do I order?
Jun 18, 2012 | Garden
Motor runs but pumping mechanism simply falls out?
A motor shop can get you parts or rebuild it for you, If it is just a impeller it's probally pretty reasonable and then you have a spare.
Sep 20, 2009 | Little Giant APCP-1700 Swimming Pool Cover...
I have gone through many of these fountain pumps
Get an industrial pump like: teel, bell&gosset or,taco check out: granger.com
Aug 26, 2009 | Little Giant Submersible Fountain Pump
Need a water pump
you can get an equivalent size pump at a store like home depot or Loews.
May 15, 2009 | Little Giant Submersible Fountain Pump
Water fountaian will not work
The curcuit should be simple. The pump is the heart or this system it draws water to the pump(if it can't then the hose is plugged, or damaged) or the pump is bad. If the pump is working then it should be pushing water to its destination. if the water comes out the pump but wont or cant push the water to its destination then the impeller is bad.
Apr 26, 2009 | Beckett Water Gardening Beckett 7124110...
Parts for Garden Treasures 2 tier fountain
You can find replacement parts on amazon. click here Amazon com tier fountain parts and search for your part. Hope this was helpful. cheers
Apr 05, 2009 | Garden
Sunterra 3000 GPH Pond Pump 203000 Logo
Top Sunterra Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Sunterra Garden Expert? Answer questions, earn points and help others
