Question about Maytag Dryers
Maytag electic dryer noise
I have a maytag legacy series electric front load dryer. It is making a high pitch squealing noise intermittently. The repair man came here and charged me over $100 to fix it. It was quiet for months and it is now worse than before. I want to take it apart. Help. I can't find the schematic drawing to do so.
  • acrausman Apr 23, 2009
    Thank you. I am going to do that right now before I lose my hearing.
    President:
  • 1,489 Answers
First, pop up the top of the dryer -- use a large slotted screwdriver under each corner of the top. There will be screws holding the front of the dryer -- take these out and take the front off. The squealing is coming from roller bushings which need lubricating. Apply machine oil to all the axles/bushings -- this most likely will stop the squealing -- and don't forget to unplug it first.
Posted on Apr 23, 2009
Maytag Legacy Series Electric Dryer
May need a new timer, I had to replace mine, easy job if you watch the video online.
Jul 08, 2013 | Maytag Legacy Series Top Load Washer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
I Have a maytag Electric Dryer the dryer is
it could be your drum glides in the front of the drum or the rear center bearing or rear rollers, or the belt idler pulley or motor end bearings going bad,you will need to remove the front cover by removing lower kick panel screws near the floor and lifting upward on front cover,then remove top cover screws located under top cover and lift up and secure so as not to break wires to control panel,then rotate drum by hand and listen for noise location
Jan 25, 2010 | Maytag PYE2300AY Electric Dryer
High pitch squeal-metal on metal contact
A lot of dryers have plastic or felt slides on the drum. This is to reduce friction as it rotates. They are probably worn off.
Dec 24, 2009 | Maytag MDE4806 Electric Dryer
Maytag dryer MDE9316AYW - while running makes a high pitch noise. Becomes softer as clothes get dryer. I assume this is because of the load becoming lighter.
This sounds like motor and/or roller bearing/busings squeaking.
Remove front and lubricate all shafts/bearings/bushings in the belt path.
Here's some info on how to get it open.
http://www.fixya.com/support/t1466561-get_top_off_maytag_dryer_see_belt
Charile
Aug 22, 2009 | Maytag Dryers
Dryer squealing?
you need to replace the felt around the door if it is not this it is in the motor and I would just use it tell it dies then replace. thank you for using fixya
Jun 19, 2009 | Maytag MDE308DAYW Electric Dryer
SQUEAKY DRYER
HOW DO YOU ACCESS THE REAR DRUM TO APPLY THE OIL?
Feb 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis dryer
Why is Maytag Atlantis is not drying like it use to?
Nov 12, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Top Loader Washing Machine Legacy Series
The drum should be on center. It sound like a damper pads issue. The damper pads are located beneath main support housing on base's machine. Check that they are on place and not broken. Good luck !
Jan 22, 2007 | Maytag Legacy Top Load Washer
Dryers Logo
694 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
