Question about Samsung Televison & Video
Samsung HLS6188w shuts off by itself
We had a big home improvement going on, we had to keep this TV [HLS6188w] in the storage for almost 9 to 10 months, we did not use it at all. Now improvement is done, we hook the tv up, but we are noticing strange behavior after we turn it on, "It shuts off by itself after some time very frequently", some time it happens every 15 to 20 minuts, some time it happens after 2 to 3 hours, we are curious, what could be the issue - After we bought this 2 years before, we did not use it much so there is not a question of replacing bulb, it could be due to we move the TV from one room to another room, not sure. ?, Was it because TV was not on for more than 9 months causing some circuits/capacitors/anything to get cold ? not sure, btw, I do not have a warranty.
Any help would be appreciated.
Thanks in advance,
-Munno Rasania
  • 179 Answers
SOURCE: Samsung HL-R5067W "Powering Down"
the hlr series had a few problem with intermittent turning off. one was the lamp door cover switch, the other was the thermostat.. neither one is very costly and a good tech should be able to replace bothe parts at the same time..
Posted on Nov 29, 2007
  • 4 Answers
SOURCE: NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
had same problem. update tv software with a usb drive. do not take the tv apart. its easy download to computer unzip to usb drive and put drive in right side of tvs usb slot with power off, then turn power on, you should get an update screen.
did not work for me the first time i had to format usb drive to fat (not fat32) and then unziped to the drive took 10 minutes to update. I have tv 60PP9200D/37
Posted on Apr 28, 2008
  • 3 Answers
SOURCE: Samsung TXR3079WHX TV shuts itself off!!!
transistor bad shorted tr-power j6920 org. part#0502-001230 located near flyback.don`t no location #
Posted on Sep 09, 2008
  • 1030 Answers
SOURCE: RCA 52" Menu Keeps Popping Up and Down
I see this alot at the shop ... the front panel buttons have become damaged. THe best coarse of action is to replace the front button cuircit board assembly... **** there is a tempery fix untill you get the part... remove the front panel and take button cuicit board out...just use remote to control the tv. This is also a way to test to see if this is the problem.. if you romove the connector to the buttons and the problem goes away then the buttons are the problem. you get get this cuicit board at union electronics. You have to get the extended model number off the back ussally d52w20yx1 or yx2 or yxsomething...not to difficult a repair
Posted on Nov 07, 2008
SOURCE: TV shuts off every few minutes
The problem lies not with the manufacturer but with the technology. While DLP is one of the clearer, crisper rear projection technologies, it is still rear projection, and therefore the most unreliable of the TV technologies, LCDs being the most reliable and the least expensive to fix (relatively speaking). Projection TVs require that the lamp be changed every 2 years (with about 6 hours a day of use) but this can be as often as 6 months to a year for households that use the TV all day long. Lamps cost 150 to 200 dollars in most cases. Beside the lamp, the other parts in the TV can go as you have learned and they are not cheap to repair. I would recommend an LCD tv as they usually manifest problems in the first year (under warranty) if they are going to have any at all. No man-made technology is 100 percent, but I have to say that Samsung is an excellent brand, very high quality, and more features than the competitors. I own one myself (LCD) and have had it for over a year with not a single problem and it gets heavy use as I use it for HD cable, PC monitor, blu-ray, and Xbox 360.
To wrap things up, let me just say that were this problem to be fixed, being a projection TV you might run into these issues in another couple of years again. I would cut my losses and try an LCD (current generation plasmas are also good but they are super expensive to fix if they do break).
Posted on Mar 11, 2009
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Jan 05, 2016 | Televison & Video
The heater runs for a few minutes and then it turns itself off it's on stable ground and everything
My furnace keeps shutting off, only runs for about 5-10 mins ...
? 5:19
https://www.youtube.com/watch?v=pEng9mtBtKk
Dec 15, 2013 - Uploaded by shannon122005
My furnace shuts off before reaching the set temperature on the... and then i turn switch back on , the furnace running about 4-5 hours and then ...
Furnace starts, then shuts off. - Home Improvement ' DSLReports Forums
www.dslreports.com > ... > Home Improvement
DSLReports
Dec 1, 2009 - 30 posts - ‎18 authors
[HVAC] My gas furnace cycles off every 6 minutes. ... This cycle will repeat a fewtimes, then usually after the second or third time everything ... How long is it after the big blower cuts on that the gas shuts off? ... Turn the furnace on, once the inducer blower is running you should read 0 volts (switch is closed).
Jan 03, 2016 | Heating & Cooling
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
? 4:41
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
My tv keeps shutting of after I replaced the lamp.
Please recheck new lamp is placed in its position correctly and lamp cover is well seated.
Hope that will help to fix TV.
Sep 18, 2009 | Samsung Televison & Video
My TV shuts itself down by itself
Poer supply is the cause of the shutdown and would need to be replaced. These cost around $150 bucks just in parts the labor you would need to find someone that knows just what there doing or you could wind up into the hundreds, Thanks
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
TV model HLS6188W start to shutting off all the time.
If TV lamp has not been changed in last 2 years then most probably its Lamp issue in TV and requires lamp replacement.
Apr 16, 2009 | Samsung HL-S6188W 61" HDTV
Samsung DLP 62 inch turns off by itself after being switched on
take off the lamp access door on the back and find the safety switch that the door pushes on. unplug the connector from the switch and put staple into the connector to short out the cable. Switch is probably bad. worked for me. same problem.
Apr 07, 2009 | Samsung 61" Slim-Depth DLP HDTV
My 42 inch samsung dlp tv keeps powering off on it's own. Why???
Your Lamp could be going out.they only play for 5,000 hr some 8,000 hours do the math.
Nov 30, 2008 | Samsung Televison & Video
Televison & Video Logo
103 people viewed this question
Jerry Greenberg
Jerry Greenberg
