Cielo tv playing dvd in black and white - Televison & Video
  • 17 Answers
SOURCE: TV SETTING
how do you have the dvd player hooked up to the tv
Posted on Dec 10, 2007
  • 108 Answers
SOURCE: DVD'S Play only in black and white
In UK this occures when an NTSC picture is played from a DVD player to a TV which cannot enitrely hand NTSC format. Possible this will happen in the reverse for USA.
Also my TV cannot handle SVHS signals and also displays them in black and white.
Try changing settings on the DVD Player to Composite or RGB.
Regards
Posted on Mar 10, 2008
  • 476 Answers
SOURCE: DVD plays in black and white
Which type of cable are you using to connect the DVD to the TV?
Composite video - yellow RCA?
Component video - red / green / blue RCA?
S-video?
This problem could occur if you are using composite video and have it plugged into one of the component video inputs.
Alternatively it could be that you are trying to play a PAL (European DVD) source into the NTSC input.
Posted on Mar 17, 2008
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Posted on Nov 29, 2008
konzzz
  • 255 Answers
SOURCE: TV SETTING
check the tv system setup of the DVD.
Posted on May 28, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
#dhb300b DVD player plays only black and white my TV is a JVC HD TV with HDMI cable from driver TV box hook up DVD to TV audivo to audivo video to video set TV to component program DVD to TV but plats
The yellow/red/white cables are COMPOSITE cables. COMPONENT cables are RED/BLUE/GREEN. You can buy those at any electronics store. Your best bet, though, is to stick with HDMI if you can.
Jan 21, 2015 | JVC Televison & Video
Phillips TV shows black and white only when playing DVD
If the DVD is built into the TV, try and DVD cleaner Disk.
If it is external, try a different DVD player and disk.
May 27, 2014 | Philips Televison & Video
My dvd player is playing in only black and white. I cannot figure out how to get it to play in color
I have the same problem.My dvd plays in Black And White.I found out A bulb in the tv burned out.The tv will still play color,but any dvd player will play in Black and White.The bulb is $130.00 to 230.00.Hope you have a warrenty like i doo.Thanks Hope ive helped.John from Riverside RI.
Nov 16, 2009 | Panasonic DVD-S35 DVD Player
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
TV SETTING
May 28, 2009 | Vizio GV42L 42 in. LCD Television
Regards
Mar 10, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Dec 18, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
PLAYING DVD
check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Aug 13, 2007 | Koss KS2503 System
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
