Question about Whirlpool GFE461LVS Stainless Steel Electric Range
When trying to use oven an error message reads function not available. How do I diagnose this problem?
FRIGIDAIRE OVEN BEEPING ERROR F 31 MESSAGE
Hello parmantal - Typically error code F31 indicates that the unit has a shorted probe connection problem. Try resetting the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and this will usually clear most false codes. If it proves to be ineffective, contact a professional to move forward accurately. The technician will need to check the resistance and/or harness between the EOC and probe connector. Depending on the diagnoses part(s) will need replacing.
Dec 18, 2012 | Frigidaire FEF352 Electric Kitchen Range
Jennair jer8855 range was beeping , had f9 message, oven door locked and oven won't turn on. I turned circuit breaker on/ off as per a previous post which took away error message, unlocked oven do
The latch has most likely become dislocated from its mounting points and will need to be secured back in place correctly.. Check the mounting screws to see if they are loose. Then move the latch back into position and tighten them securely. If not then the error will just come back. The latch mechanism may also need replacing altogether itf it is damaged.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Sep 08, 2012 | Jenn-Air JER8855 Electric Kitchen Range
I own a wall oven/microwave combo, GE JKP76 and JKP77. I recently turned on the Autoclean function however, once completed the door remains locked and there is an error message flashing "F2" and...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Mar 05, 2011 | GE JKP15 Electric Single Oven
The oven warms up and then starts beeping and flashes f10 err.
The "F10" oven error code means "Runaway temperature".
If you have technical skills, you can try to diagnose and repair yourself, otherwise, call a qualified appliance repairman.
Locate the temperature probe wire plug at the Electronic Oven Control (EOC) and measure its resistance. It’s supposed to be about 1100 Ohms at the room temperature.
If the reading is wrong, replace the oven temperature probe.
If the reading is correct, replace the EOC.
Jan 28, 2010 | Kenmore Ovens
Fr message for lower oven
This appears to be a communications error between the control boards. There is a test mode that you can enter from the panel, which might help you diagnose the problem further:
1. Turn power at break off. Wait a few minutes. Turn power back on.
2. Push and hold "Stop Time" key for 10 seconds
3. Now you are in test mode. You can push each button to test it's function while you hold it down.
4. Push cancel to exit test mode.
If you conclude a control board failure is the problem then we may be able to save you some money. If you can have the board removed, we repair them at www.fixyourboard.com
Oct 09, 2009 | Jenn-Air Ovens
F14 error message
First change the fuse. Then if it still isn't functioning properly, you may have to replace the lamp, in which case you should contact a specialist. Details can be found in the Instructions Manual.
Go here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
and enter EB270 and click the Go button.
Then download the PDF file of the manual in English (EN)
Hope this helps :)
Chris (ziraffa)
ps Someone else on Fixya claims to have fixed the F14 problem by changing the PCB Board, whatever that is.. but there was no further rating or feedback given. That's all I have.. Good Luck!
Jan 11, 2009 | Gaggenau EB270 Electric Single Oven
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Over door locked
Error code F93 means the lock motor assembly spent too much time to lock. Someone needs to read the continuity of the lock switches and the door switch and apply 120 volts ac to the lock motor to see if it will run. If the oven is less than 1 year old you should schedule service and let a technician diagnose and repair the problem. If you want to repair the oven yourself make the checks with a volt/ohm meter and send another email if you need more advice.
Dec 17, 2008 | Frigidaire FGB24S5A Gas Single Oven
E1 and f5 error/Door locked
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Dec 22, 2007 | KitchenAid KEBC207 Electric Double Oven
Whirlpool GFE461LVS Stainless Steel Electric Range Logo
32 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
