Indesit WD12X programmer keeps turning
I have an Indesit WD12X and machine starts to fill then programmer keeps rotating - pumps ok- spins ok- when put onto last rinse position programme button clicks forward one position and starts to fill and drain at same time whilst prog knob rotates all on its own. Any ideas please on how to rectify ,many thanks
2 Suggested Answers
SOURCE: indesit wd12s washer dryer
hi same prob as i had you need to change your board in the bottom of the machine the indesit wd12s was plaged with probs shop around tho i got a board for £23 you can pay upto 80
Posted on Nov 14, 2007
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
I have a fischer and paykel top loading washing machine for the last few years that that given use excellent service. In the last month when a programme is run the machince gets stuck at the rinse cycle...
Hi dude - is this a replica of the lights - where I put 0 theres no light, 1 is a light ok you follow? on the top is 8 lights from left - right the first 5 is always green, next 2 is orange & last is red! so I will try and see if we are on the same track...
Here goes - 0010 0101 is this what you have? - if yes then the pump is either overheating of severely blocked - more likely to be overheated.
This is how the washer works. it fills, washes then rinses - now pump starts up as machne joggles and agitates to set up for a spin, then final rinse - as it goes to end it does the same as in rinse.
Therefore I tend to think we would be looking at the same lights on your machine - to my illustration -
Keep the chin up - if you need to replace the pump then look up other F&P request or look up my solutions to help you.
KK
Jun 24, 2011 | Fisher and Paykel Washing Machines
I have a 2 year old indesit wd12x been fine
could be the catch has broken you may have to force it open and new complete door is about £25.00
Mar 01, 2010 | Washing Machines
The dial stops on 2 will not spin or empty when switched manually it move round like a second clock through the programes. I have had the pcb. board checked by post with Q E R and they say its ok.INDESIT...
hello any spin problem can be down to the module board the fact you've had turn the dial which is the programmer sound like this is the fault if this is the case you may need to be looking for new washer. sorry to be negative i hope you find a solution
regards
shaun
Feb 28, 2010 | Indesit W 123 Front Load Washer
Indesit programmer has a mind of its own
I have LG Washing Machine WF-S6607 when I START after 5 Second it will be stop and alarm to come up on Rinse MODE. what I do?
Oct 17, 2009 | Washing Machines
Indesit washer not spinning
I had exactly the same problem. All seemed ok, except no spin. I followed Shaun's advice and replaced the module board. Cost of about f£23 from ebay, but similar price on espares.co.uk. Fixed it. Thank you.
Aug 04, 2009 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Indesit w11
does it have a manual programme knob?if it does ,probably the internal contacts do not mesh so it stops at next step (programme)but the water pump keeps on making the noise.
try turning the knob by hand when machine stops before entering next programme cycle.if machine starts ,programme knob is the problem.
Mar 21, 2008 | Washing Machines
Washing Machines Logo
324 people viewed this question
Top Washing Machines Experts
