Question about Kenmore Freezers
Kenmore 28161 freezer setting - Kenmore Freezers
Managemylife com sears
You have a Kenmore upright, which you set on ZERO? WHY?
Every time you open the door all of the cold air falls out and it has to start over in the cool down cycle, the fan stops to NOT push all of the COLD out while the door is open - you should consult a professional. Not for the freezer, for your ability to understand.
Aug 18, 2014 | Kenmore 13.7 cu. ft. / 388 liter Upright...
I accidently turned off freezer.How do i turn it back on?
Turn the interior temperature control back on by setting at approx halfway between "off" and "coldest". (Make certain the branch circuit is hot - you should hear the compressor turn on when you set the control, possible an interior light will come on as well).
If the freezer does not run, check to see if you accidiently pulled the flash defrost plnger (if equipped). (See age 8 in your manual).
If you don't have a manual, you can download one here:
ShopYourWay KENMORE Upright Freezer ShopYourWay
(This is for Kenmore model 253.23024-101 or -102).
Apr 22, 2014 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Just bought a used kenmore elite frost feee freezer model 3 253.26072100 with an alarm and in great shape however there is no manual and we do not know how or what the temp settings should be at. We have...
You can view/download the manual at
http://www.managemylife.com/mmh/owner_manuals/8259/KENMORE-ELITE-Upright-Freezer-L0603500
Jul 16, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Feb 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Sears Kenmore Deep Freezer settings
It sounds like you have a circulation problem.
Spread out the packages so the freezing air can circulate.
  • Check that the condenser fan is on
  • Check that the coils are not covered with lint and dust especially if they are under the freezer.
  • you may need a tech to put freon in the system.
Apr 06, 2009 | Kenmore Freezers
Freezer/kenmore
the settings usually are:
off - on - superfreeze. you just want "on"
Nov 16, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
i tilt my chest kenmore deep freezer to remove water when cleaning it by the time it was connected it didnt work
Nov 10, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
206 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
