My Quark files are being duplicated on my Apple HD labeled chmod 740
  • kramsey Apr 24, 2009
    Thanks for your suggestions. I am not working off a server. Just my Apple PowerMac G5. I will try the "Save As" and also start opening files directly through Quark and see if that solves my issue.
    Thanks agian,
    Karen
    Brigadier General:
  • 3,917 Answers
Hi.
Have you checked your preferences to see if auto-save and auto-backup are on? I assume that you are working off of a server. I am having the same issue when working off our server. If I click to open a file it will create a duplicate with the name "copy1" attached. I can save once only, subsequent saves must be made using "save as". What is actually happening is that the first save is activating the "Stationary Pad" option, that can be seen by "getting info" on the file. If I uncheck that box the file will open normally, but the option will be re-activated after the first save. The only workarounds that I can see is to open files by dragging on to the application, or to use the "Open" command from within quark. This eliminates the duplication, but after the initial save you still have to use the "Save as" command.
I've had the same problem as you guys. I found a little bit of a workaround by opening the file directly in QuarkXpress instead of double clicking on the file to open it. So far it seems to work.
Check out this website http://www.macwindows.com/quark.html it has some good info on how Quark works with AFP servers.
We are having the same duplication of files problem, with Quark 6.52 files opening in Leopard.
A number of folks in the local MUG (Mac Users Group) have said that they have run into weird problems with Leopard when it was installed using the upgrade option. But when they went back and did a clean install (wipe and install) that cleared up the problem.
Thanks Have a nice day.
Posted on Apr 23, 2009
  • e-Guru
    e-Guru Apr 24, 2009
    No problem.
    Thanks
    Please rate fixya.
Overprinting quark xpress demo on all documents
Enter a valid product key. If Quark Xpress doesn't nag you for the key with an automatic dialog box, you will probably find the registration info entry in Preferences. If you have already entered the key, something corrupted the key file, so try entering it again.
Feb 27, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Quarkxpress 8 quits during launch. Macbook pro OS X 10.5.6
It could be that your quark preferences have corrupted, I would go to your users folder then go into the library folder, then the preferences folder and then the quark folder within the quark folder there should be a file called "XPress Preferences.prf" move this to the trash (But do not delete it yet). When you open quark next it will recreate the preference file and hopefully that will sort it out.
Mar 08, 2010 | Apple Computers & Internet
My father recently " Backed up" my Macbook and when he gave it back my desktop was wiped and when I went into the finder and clicked on the desktop folder it said it couldn't be opened because I didn't...
Simplest way is to run disk utility and hit the repair permissions button.
If you want to get all fancy about it you can use the terminal (also in utilities folder) and use chown or chmod. If you want to learn those commands type "man chown" or "man chmod" The man command brings up the manual page.
Much easier to use disk utility though.
Jan 10, 2010 | Apple aluminum 13-inch MacBook laptop-...
Quark 6.5 error code 10660
Just open the file once and save it and it should work.
You can also try adding a .qxp extension to it and then try opening the file
Jun 16, 2009 | QuarkXPress 6.5
I recently installed Leopard 1.5.6 running on a iBook 1.2 GHz PowerPC G4. The software worked fine for a while. I am unable to open files, folders, applications, using the touch pad or external mouse. Can...
Try unlocking them by clicking the lock icon, it would ask for admin password. Each read write permission to yourself.
If this doesn't work, try creating a new super user account on your machine and run Disk utility and ask it to repair your file permission. Launch terminal and type this.
find . -type d -exec chmod 777 {} \;
find . -type f -exec chmod 777 {} \;
or you can try
cd /Volumes
this would display volume name.
chmod 0777 volumeName
May 15, 2009 | Apple Mac OS X v10.5 Leopard for Single...
Pages display as duplicates
Are you working on Mac machine or a windows one?
Dec 01, 2008 | QuarkXPress 7 Full Single User Mac/Win...
Quark picture files
Since you're copying your Quark file to an external HD, I assume that you're also copying the image files? What you should do before copying to the external HD to work on the file at home is under the File Menu, use the 'Collect for Output' feature, which may take a while depending on the size of your file, number of images, etc., but then you can use the Quark file from the xternal hd, and back and forth to your computer without having to relink the picture files all the time.
Jul 04, 2008 | Quark Academic QuarkXPress 6.1 for PC
6.52 KERN_PROTECTION_FAILURE
Please let me know when exactly does QuarkXPress crashes
May 28, 2008 | QuarkXPress
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
