Question about SmartParts (1DPFSP01) Digital Picture Frame
Mydidgital picture frame has no power aafter pesses through euse
My 10" digital not working it comes on but not reponding the icon dont come up its not doing anything please help
hi
try to see if you have a reset hole in the back or sides if not then try to reconect the battary or to empty the battary .
May 17, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
Picture of the tv shrinks to half
Could be a failing power supply. Not surprising after 10 years of use
Mar 22, 2017 | Televison & Video
Dodigital frames need batteries or electricity?
Some digital picture frames work with batteries, while some work with a power plug, and some have the option to use either method. Running off of battery power can be handy if a power source is not readily available. For a frame that is going to be used 24/7, a power plug is more convenient.
Read more: How Does a Digital Picture Frame Work? ' eHow.com http://www.ehow.com/how-does_4613713_digital-picture-frame-work.html#ixzz2IsRZGCgP
Jan 24, 2013 | Photography
NO Picture or Sound on my FLM 26-32
Either one of two problems, the main power supply has an issue or has gone bad. 'Not supplying the correct voltages to your processing/controlling board' or that you are having problems with your processing/controlling board. My guess is the main power supply board.
A Good TV Service Shop would give you an idea of what the cost of repair should be. Call around.
Blessing,
A/V Media Tech Guy
Jul 22, 2009 | Polaroid FLM-2632 Television
Where to get power supply?
http://www.shopping.com/xPC-GeCube-Pandigital-8-Inch-Digital-Photo-Frame-with-2-Interchangeable-Frames
Mar 09, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
NO PICTURE ON TV
try pessing tv video button you should then atleast seeon screen display if you do press it untill you get a picture.
Feb 27, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I just got the frame and it won't power on.
Have you already got pictures on there.
It won't display unless it's got pictures. On my copy i plugged my Frame into my computer. then pushed in a memory card to the Frame and dragged and dropped into the frame itself.
If there still isn't picture then there must be a setting on the Frame in which can make them go through the pictures.
Dec 20, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
Digital picture frame wont power back up
Test the power adapter. If the light is flashing, it may not be getting the 12 volts that it needs. You can test it w/ a voltage tester or if you don't have one, take it to Radio Shack and they can test it. If it's dead, or short, replace it and then the frame will work again.
Dec 15, 2008 | SmartParts SP15MW (092566981886) Digital...
SmartParts (1DPFSP01) Digital Picture Frame Logo
Top SmartParts Photography Experts
Joseph Hoffmann
Tony
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
