You will need a pedal wrench or a fairly thin open end wrench. Pedals are threaded or a good pedal wrench. The left pedal on bicycles unthreads in a clockwise direction and the right pedal unthreads in a counterclockwise direction. The thread back in oppositely. Theoretically they self tighten as you pedal. When buying the new pedals, make sure you take an old one with you to make sure that the threaded shaft is going to be the correct diameter. Any fairly wide pedal with rubber grips would be a good choice. A past customer even used two blocks of wood screwed together through the old pedals as they were too tight to remove. Hope this helps and wish your Dad well.
