Question about NorStar Lands Phones
Nortel p0728290 change system time
Need to reset the time on a client's nortel phone.
It depends on which Nortel System your client uses, and which level of software they have in the system. You can try "Feature * * T I M E" (Feature, star, star, 8 4 6 3). If that doesn't work, we'll need more info about the system. Good Luck!
May 20, 2010 | Nortel Norstar 16-Line PBX Speakerphone
Cant change time and date on nortel t7208 phone tried the f xx23646 and so on, nothing
Programming on the nortel system is done on M 7310, M 7324, or T 7316 sets only.hopfully the receptionist station has one of the larger sets.
Apr 15, 2010 | NorStar T7208 Corded Phone
Change Time
THe older norstar systems you had to go into programming to change time and on the newer systems press feature * time on your phone and follow the prompts. On the older systems go in to programming press feature ** 266344 (config) then pswd 23646 (admin) on your key pad this gets you into programming press next until you get to change time. You need an overlay which can with your phone system manual. If need more info please ask agian hope this helps.
Nov 17, 2009 | Nortel Norstar 16-Line PBX Speakerphone
How do I change the time on the display on our Nortel phone system?
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming2.gif mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___" 18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Nov 02, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Can't Change Time
Do Feature **ADMIN, Then go to Time And Date, and enter the time, here is a video on how to do this
Jul 08, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Time change
Below is a link to instructions on how to change the time on a Norstar system
Norstar Time change
Mar 11, 2009 | NorStar T7316E Corded Phone
Changing time on Nortel networks Phone system
Sorry, the tester012 was an accident, so I wanted to repost in case there were more questions on this.
The answer still stands for most Nortel PBXs:
To set the time and date of your system you program in load 2:
Step 1) LD 02
Step 2) STAD "Day Month Year Hour Minute Second"
i.e. STAD "24 11 1976 15 41 49" =
November 24th 1976 3:41pm 49 seconds"
To test it...
Type: "TTAD" - (this tests time and date)
But I also wanted to clarify that it is in the manual, but since there are multiple manuals with a Nortel PBX, that you need to look in the LD (or Loads) in them. This particular one is found in LD 02.
Another site to check out for a crash course in LD for Nortel (in case you have similar issues that you need assistance on) is this one here:
http://www.pbxinfo.com/meridian-systems/16288-meridian-crash-course-programming-guide.html
I hope this has been helpful, again I am sorry for not having logged in properly to be notified on more explanation when I posted Solution #1.
Apr 15, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Changing name in nortel T7316E handset
We would like to change the name displays on our phones
Mar 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Lands Phones Logo
49 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
