Question about Briggs & Stratton Garden
Huskee Easy Cut 14.5 hp riding mower will not stay running. Immediately dies after cranking
    Sergeant:
  • 406 Answers
Sounds like your float in the bowl is sticking..not allowing fuel to continue to feed gas to the carb. Take the bowl off and remove the float and needle valve and clean them..Note check and see if their gas inside the float itself..some times they develope a small rust hole partially filling the float.with gas. ..not allowing sufficient fuel to feed the carb..will need new float. GOOD LUCK.
Posted on Oct 10, 2014
highspeedsan
  • 61 Answers
SOURCE: riding lawn mower runs but when engaged it
You need to check the belt on the deck. Something is binding or stuck. Could be a frozen pulley. Could also be the kill switch under the seat. If it is free, go get it.
Posted on Apr 26, 2009
  • 71 Answers
SOURCE: Craftsman 42 inch riding mower. Runs great
how old is your plug? try cleaning and regapping it or replacing it at any rate make sure it is gapped correctly also make sure there is no rust dust or debris is on flywheel or coil also the flywheel keyway does more than hold the flywheel in place it servs as a timing pin and sometimes the slightest wear on it can cause the machine to start hard but otherwise run great good luck hope you find the problem.
Posted on May 02, 2009
  • 391 Answers
SOURCE: MTD 12.5 HP Ride On Mower won't stay running
It could be a needle valve sticking or a mal-adjusted float but more common is a fuel filter that is restricted, once you use up the fuel in the line and float bowl it runs out and dies. A less common but easily tested issue is when the mower has run for the amount of time it begins to sputter and die, loosen the cap on the fuel tank just a bit, if it helps or resolves the issue the vent in the cap may be clogged.
Posted on May 26, 2009
  • 376 Answers
SOURCE: mower will not drive
Usually, that's an indication the the seat switch is not working. It's like getting off the seat without locking down the parking brake or getting off the seat with the baldes engaged, same result...engine dies.
Posted on Jun 03, 2009
SOURCE: huskee 42 inch drive belt
does anybody know what kind of drive belt a huskee 24 horse 42 deck takes?
Posted on May 29, 2010
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Huskee Riding Mower wont start
Try rotating the engine manually to check for any binding. I would also check the amp draw on the starter.
May 21, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Huskee 46''CUT need cables gas hose battery ingtion switch
Contact the local dealer with the model of the machine ( will be on a plate under the seat )
Apr 06, 2012 | Garden
I have a Huskee riding mower- 18.5 hp with 46 inch cut. The mower has 3 blades. When I engage the blades the belt squeals but will go ahead and cut until it gets hot at which time it will stop pulling. The...
check the pullie blade bearing if it is going out it would make the belt squeak and when it gets hot it will make the motor lug down I have worked on mowers for 41 yrs.
Aug 14, 2011 | Garden
I need to know the belt sizes for a Huskee Supreme LT 23 HP 46" cut model # 13BS608H131 SERIAL # 1B173H10127
I serviced my tranny. Opened it up, found the problem, used a washer as a spacer, has worked ever since, and the mower is now about 11 years old.
Jul 09, 2011 | Garden
Have new battery, mower crank a few seconds then just start clicking. but the lights are bright, the mower is a older model HUSKEE 24 HP 54in cut
The starter solenoid is most likely faulty and not carrying enough amperage to the starter motor. Regards Phil
Apr 12, 2011 | Mtd Garden
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Mar 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cub Cadet Model SLT1554 PROBLEM: Engine cranks, runs for 1 second then dies. Cranks every time but dies immediately
Sounds like another carburetor blockage. Remove the carburetor and clean out all the orifices in the main jet. Also, check the float for leakage.
Sep 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
When mower gets hot it cuts off crank back up run a min cut off
1 of 2 things happening
first change the fuel filter seams that the gas is vapourizing
If that does not fix it replace the engine coil as it heats up it is breaking down in voltage causing the engine to die
Apr 05, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
52 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
