Question about Aquatronics AMS602WR Coaxial Car Speaker
Have a MS1000 with no book. How do you pull the fuse? The radio stopped and I think it is the fuse, but cannot seem to pull it out. What am I doing wrong? Thanks in advance.
Hi does any body no where the fuse for the radio is kept in a 53 plate Peugeot partner van,radios stopped working surspect fuse,cheers thanks
If you pull the radio out, the fuse should be slotted into one of the conectors that go into the back of the radio unit, normally a 10a ...well on mine it is which is a 51 plate, think its the same model.
Feb 08, 2016 | Peugeot Cars & Trucks
Pull jb power fuse15 stop drain no fan controls or radio
i cant under stand any of that.,i get JAB, and fuse 15
  • is this ?
  • battery drains over night? why did you say drain,if not.?
  • fuse 15 is ok. wild guess, sure, lots of loads, only a few fuse.
  • Hvac blower dead,
  • Radio dead
  • yes, the FSm does cover all that. sure.
id do the radio,so simple. 1 wire. for power, one fuse,
toss coin
03 GC WJ jeep it is zzzzz, slow internet on the beach
cant open free FSm. grrrrr
got it
jb f5 and 30 is Radio
f5 is only memory so fuse 30 is blown, why not test all fuses, keyon, 12v on both sides, and forget books. this works.
the blower is more complex. (controls)'
blower is pdc f1
and jb 20
looks yourself
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
free,posted over 100times now under GC
Jan 17, 2015 | 2003 Jeep Grand Cherokee
Trip Panel Screen, radio and phone charger plug-in not working
it sounds like u have a blown fuse if u have an owners manuel look in the fuse section and find the fuse for ur radio pull it out and see if it is blown.
Feb 07, 2013 | 2005 Acura MDX
I have a 1999 ford mustang and the radio stop working. I think its the fuss. but the fuss panel is not marked. were is the radio fuss.
best way to do it is to get yourself a pair on needle nose pliers and start pulling fuses one at a time.
Jun 28, 2011 | Ford Mustang Cars & Trucks
We have 9-5 2006 saab that has a dead short and it seems to be in the radio area. when two fuses are pullled for the radio the drain on the battery seems to stop, but we don't know where the dead short is?...
Alright, if the radio is the cause then pull the radio,unplug it, and see if you have the same result as if you pull the fuses. If not then find out what else is on those fuses.
Nov 11, 2009 | Dryers
96 goldwing radio no volume
Had the same problem, there is a fuse on the left side, way down under all that stuff, it is just a line fuse to the radio, it has blown, it is not in the book, and it hides real good. Drove us nuts looking for it. And when we were ready to buy a new radio, we found the fuse. Took 8 hours to totally dismantle bike to find it. Will take you 10 minutes, good luck.
Jul 24, 2009 | Honda GL 1500 Aspencade Gold Wing...
02 VW Jetta locks, remote, lights, windows stopped working
Same problem with an '03 Golf--remote entry, power windows, and interior lights stopped working. This was easily fixed by replacing fuse #14, (10 amp), located in the driver's side fuse block.
Mar 21, 2009 | 2002 Volkswagen Jetta TDI
03 chev silverado radio on but no sound
My van radio runs on 2 different fuses- both in the fuse box under the dash. One runs the lights the other the sound. Hope this helps.
Jan 11, 2009 | 2003 Chevrolet Silverado 1500
Lights/Horn/Radio Do Not Work
you would have to look in your book or the fuse labeling because the fuse layout/naming is specific to each brand. the radio/audio system should have its own one. if you cant seem to figure it out, just keep pulling fuses and see if you can find a bad one.
Oct 20, 2008 | 2004 Dodge Durango
Aquatronics AMS602WR Coaxial Car Speaker Logo
Top Aquatronics Car Audio & Video Experts
xxxxxx xxx
Are you an Aquatronics Car Audio and Video Expert? Answer questions, earn points and help others
