Question about Motorola Mobility RAZR V3
Earpiece problem no sound can be hear - Motorola Mobility RAZR V3
  • Anonymous Nov 14, 2007
    No sound from ear piece. The only way to communicate is with the speaker phone on.
  • finmgmtsys Nov 19, 2008
    While using the earpiece I can hear perfectly, but the person I am trying to talk with cannot hear me. I have three ear pieces ( all "Motorola Brand") and they all have the same problem. Is there a "fix" for this problem. The earpiece worked fine until recently.
    Chuck
  • 89 Answers
Get a new one dear the only solution i am sure the it won't cost you much get those unbranded mostly from china
Posted on Sep 25, 2007
The problem lies in that the speaker is connected to the Front part of the phone and the mother board is connected to te back part of the phone. Since the speaker is not soddered correctly to the motherboard, rather it is held to gether with pressure, the contact becomes undone. Hence sometimes you hear sound and other times you do not hear sounds. The solutions is complicated: First remove the battery and unplug the phone from any parepherals/the electric socket to prevent electric shock. I'd recommend wearing a wrist grounder to provent electrostatic discharge to the phone when it is open, though many argue it is unnessasary. There are 4 screws covered by soft rubbery circles about 2mm diameter at each corner of the LCD screen. Remove the circles. Next find a screw driver that is 6 pointed star shape and small to fit the screws. If the screws are capped, apply super glue to the screw and let a screw driver set in place to remove the screws. Lift away the the front plate and look for a speaker at the top. It should be attached with an orange film called "kapton film" with wire like things on it. It should feel like an over head transparency. Now, Insert your own Kapton film *available at electronic stores, or kapton tape or under the mother board where the connection to the speaker is made. Other plastic ie electrical tape, however the kapton is graded for this type of use. By inserting this film it applies pressure nessasary to keep the Speaker held to the mother board, so really wedge alot in there to get the good connection. Reassemble the phone, but in the battery and test the sound. Keep repeating till it works, it takes a little fanagling to get it right. I have fixed a V180, V300 and one motoral razr using this technique. Hopefully it works for you.
Posted on Sep 27, 2007
SOURCE:
Whenever i make or receive calls i can not hear the other person through my phones earpiece i can only hear them if its on speaker phone how do i check if my earpiece is dead?.what to do?
It is the hardware, the earpiece, you answered the wuestion yourself.
When there is no sound thru the earpiece, try using the speake mode or a bluetooth, if both works, then it's the earpice that is damage. I have no idea what phone model you have, but it can be replace or fix.
Jan 09, 2015 | Cell Phones
Cant hear anything when I make a call
The phone may be in headset mode. If you can hear sounds through the headset but cannot hear sounds from the earpiece on the phone, it's in headset mode. Power down the phone and restart it. Otherwise no sound from the earpiece mean a bad earpiece.
Oct 07, 2013 | Cell Phones
I CANT HEAR THE CLEAR VOICE OF RECEIVED CALLER
Hello there,
There are two ways on how you can hear the caller. One is through the earpiece and one is through the phone's speaker.
Are you able to hear the caller but just not clear or with static sound? If yes, then you have a problem with the earpiece of your phone. You can test this by putting it to a speaker phone. If you can hear the caller clearly then you should have your earpiece check. Usually this problem is caused when the earpiece is often moisted or get wet. Try blowing a canned air on the earpiece.
Please let me know how this goes. Thank you for using FIxYa.
Nov 22, 2010 | Cell Phones
I have no sound. other people can hear me when i call them, but i can hear nothing...not even a dialling tone.
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Aug 12, 2010 | Samsung S8300 Ultra Touch platinium-red...
When i make a call they can hear me but i cant hear them...and when my phones rings or i when i try to play a song no sound is coming out
Take care.
Jun 29, 2010 | Motorola Mobility CLIQ Cell Phone
Cannot hear anything on receiving call bt able to hear with speaker on or on hand set......
you have to change your speaker (earpiece)
when you choose the loud speaker option,,
you will able to hear the voice,,why?because the sounds transfer from earpiece to buzzer..its same when you use headset..the sound from earpiece will transfer to headset speakers..in that case,,you need to replace your earpiece..100% your problem will be solve!!
Jun 16, 2010 | Nokia 3110 Cellular Phone
Nokia 6233 - Earpiece Problem (No Sound)
ok first of all you should open your mobile and claen it carefuly.then re pack it care fully.thats it if problem not away then tell agian me i have seen tha pic also but it is for the tecnicians if mobiles.ie mobile repairer
Apr 03, 2010 | Nokia 6233 Cellular Phone
Unit(POCKETALKER) WILL SHOW LIGHT THAT IS ON,BATTERIES CHECKED AS GOOD BUT NO SOUND; INCLUDING BLOWING ON UNIT.
If you do not hear anything, such as hiss, buzz or static, then you headset or earpiece is bad. Recommend a new headset or earpiece.
Mar 11, 2010 | Williams Sound PKT D1 H21 Pocketalker...
Earpiece on phone has no sound coming out. can talk but can't hear
i have that problem too. using the speakerphone will help but calls arent clear..
Nov 01, 2007 | Motorola Mobility i870 Cellular Phone
Motorola Mobility RAZR V3 Logo
397 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
