Question about EliteGroup P4VMM2 V8.1 Motherboard
External mic connections into the motherboard 7 cablepins
I have a p4vmm2 motherboard the mic in connection i think is damaged i have a front panel external mic input but they are disconnected they are 7 small cables to be connected in the mother board...the question is: could you tell me please where may i connect every cable in the motherboard in order to connect the external audio inputs? i see in the motherboard the 7 pins but i do not know where to connect precisely each one...coud you help me please? i shall appreciate it! jaime
  • 20 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
auiioo7
Posted on Sep 08, 2009
Testimonial: "great!"
How to disable Dell latitude E5500 built in mic so you can connect an external mic?
Just plugging in the external mike into the jack should AUTOMATICALLY disconnect the internal mike.
May 27, 2014 | Audio Players & Recorders
HOW TO CONNECT USB 2.0 TO FRONT PANEL BY HOST VIA
follow this link for information on how to connect your external USB ports.
Select the version of your board and download the manual. this will give you exact instructions.
Hope this helps.
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=0&keyword=P4Vmm2
Mar 22, 2011 | EliteGroup P4VMM2 Motherboard
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
My front panel headphone& mic connecting pcb have only 7 slots and the cable is named as 1)LINE OUT FR,2)LINE OUT RR,3)LINE OUT FL,4)LINE OUT RL,5)MIC IN(R),6)GROUND,7)MIC POWER(L) how can it connect...
FR stands for Front Right, FL for Front Left, RR for Rear Right and RL for rear left. These are speakers connections. You need a convertr cable to connect your headphones with your PC. After getting cable, connect it with FR and FL or RR and RL pair. Your headphone will be working. Similarly get the cabl for Mono to Stereo Mic and you can connect your mic too. (ehteshamhusain@gmail.com)
Jul 14, 2009 | Computers & Internet
Front panel how too
Hi slider1958,
You want to connect the new case's front sound & mic.
Just about every case will come with a pre-assembled connector for front USB's & sound & mic. Your board has a set of ten pins used just for this. They are loacted just under the boards rear external sound / mic silver housing. Noted in your manual on pg. 15. Named AUDIO1.
def37da.jpg Notice there is one pin missing. Line your case connector to match.
The manual is uncleare if you are able to use both rear speaker & front speaker at the same time. I would think not. Newer boards with HD do allow this.
Good Luck & Kind Regards.
& please vote.
Mar 18, 2008 | Intel Motherboard
Connection of Casing built in Input Leads to PCB
The manual for the MB will have a diagram. Google for the manual if you don't have it.
Feb 25, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 V8.1 Motherboard Logo
239 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
