Question about HP Color LaserJet 2600n Printer
Strange Printer Issue - HP Laserjet 2600n
I am having a extremely strange printer issue with one of our users here. We have a hp laserjet 2600n setup on the network. We setup the printer on the computer as a local printer using a tcp/ip port. When we first setup the printer it will print the test page at the end of the install just fine. Any attempts to print after that will not work. There is no errors on the printer or the computer indicating that something may have gone wrong.
We have multiple users connected the the printer and this issue only happens to one user. We even changed out her computer with a new one with a fresh install of xp pro and the issue is still there. We have also tried different drivers and restarting the printer. Any insight to what may be causing this would be greatly appreciated. Thank you.
  • 7 more comments
  • rzitello Apr 23, 2009
    The setup wizard has be run correctly. We have set the printer up on other computers the exact same way and we have had no issues with them.
    Sorry, it is Technically a "network printer". It has a built in jetDirect that responds on 192.168.1.20. The local spooler has been cleared out and restarted and when printing it seems to pass through the spooler and send to the printer with no issue.
    Yes the printer will respond to pings just fine from the computer.
    No after the initial test page during setup is printed it will not print any other pages from any program including another test page. If I reinstall it will print during the install but wont printer after that.
    The address and all other information has been typed correctly. I've doubled checked it multiple times.
    I've cleared out any previous installs and I have even go into the registry and cleared out any old drivers.
    The printer is not showing any errors at all.
    The spooler seems to respond normally. There are no warnings or errors in the event viewer concerning printers. The other printers she is connected to are: HP P2035, HP P2015, and BizHub550. All those are shared network printers. She also uses the CutePDFwriter.
  • rzitello Apr 24, 2009
    We have Tried recreating the port a couple times now to see if that fixes it but it doesn't seem to be working. We are working on swapping the network cables for her computer to see if that does anything.
  • 489 Answers
The last time I checked, you cannot set up a local printer using a TCP/IP port. A local printer is physically connected to a computer via a parallel, serial (very old), or USB cable. If the printer is connected to a switch, hub, or router via an Ethernet cable, it is by definition a network printer and the driver install must reflect this. I don't understand why it is able to print out the test page after the install. If you open up Control Panel -> Printers and double-click on the HP Laserjet 2600n in there, it will bring up the local spooler for the printer. You may have a bunch of print jobs queued up in there that it cannot currently send to the printer. You may want to clear the queue first (cancel all print jobs). Let me know if you have problems clearing the queue & I can give you instructions on how to do that one too.
Posted on Apr 23, 2009
  • 5 more comments
  • ultimitloozr Apr 23, 2009
    Can you ping the printer from that computer?
    From the affected computer, can up pull up the properties page for the printer or send another test page?
    Since the driver cannot communiocate with the printer but the printer responds to ICMP requests it leads me to believe that there was a typo when entering the address (a comma instead of a period, etc.). I can't count the number of times I've done that one! Can you pull up the printer properties to verify the printer's IP address?
    Open up Device Manager. In the View menu, check the 'Show hidden devices' option. The list of devices should automatically refresh and you should see a section for Printers. Open that up and see if there are any remnants of previous installs of the printer there. If there are, uninstall them, restart the computer and attempt to print again.
    In the device manager again, is there any kind of error condition indicated in the Device Status box on the General tab of the printer's property pages? (It displays differently here than any other location where you can view printer properties.)
    Can you send a large enough print job so you can watch the spooler responses? Are there any entries regarding printing in the Event Logs other than informational about jobs entering/leaving the spooler? Are there any other printers configured for use on this system, are they HP models after the LJ6 series (different driver architecture used), and do they work?
    Well, it isn't a problem with the HP UPD since the other HP printers are working. The only other thing I would suggest is to open up the printer properties, go to the Ports page, unselect the current port it is using and use the Add Port... button to create a new standard TCP/IP port. Had that type of problem with a plotter about 10 years ago. Both were configured identically, but it wouldn't use the one the installer created.
    Right now, I'm attempting to break a similar setup here to reproduce the problem. No luck so far, but I'll keep trying....
    President:
  • HP Master
  • 990 Answers
Hello sir ; Sound like you did not tell wizzard that's network setting, don't you?
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Red prints orange instead , i have a hp color laserjet 2600n
Before processing the elighment, ensure that all cartridges are genuine one. In printer menu >go to 'system setup' enter>"printing quality" enter > "calibrate color"..enter...
after completion of the calibration check the quality of print..
Sep 13, 2011 | HP Color LaserJet 2600n Printer
I can't romove drive HP 2600n in my computer! please help me!
Problem with the HP Color LaserJet 2600n Printer
Reinstall the HP Color LaserJet 2600n Printer driven...
Then try again to remove the driver.
sure you can remove the driver...........
thank you...............
Jul 23, 2011 | HP Color LaserJet 2600n Printer
How to clean an hp laserjet 2600n paper feeder
Hi There,
Hope this should be usefull : Please follow the below link :
Link :http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=446153&prodTypeId=18972&objectID=c00314469
Thanks Please vote for me if this solution helps resolve your issue. Enjoy and Cheers !!!!
Oct 28, 2010 | HP Color LaserJet 2600n Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
HP Color LaserJet 2605dn is ready - but folder
it is problem your printer driver is not properly install or data cable is unpluged
Aug 17, 2009 | HP Color LaserJet 2600n Printer
Strange Printer Problem - HP LaserJet 2600n
Sounds like a permission's issue,
Check her/his permissions on the printer's list.
Hope this helps
Regards
Richard.
Apr 23, 2009 | Canon Pixma MP500 All-In-One InkJet...
Hp laserjet 3000 screen does not work and pc cannot find printer
If your printer is a HP Color Laserjet 3000n the issue you are having may lay within a small complact flash card on the Formatter board. The only reason I sugjest this is because I am currently working on one and when I removed the card and started the printer up the LCD would not display. But you could also have a bad DC Controller card.
Apr 07, 2009 | HP Color LaserJet 2600n Printer
Can't print after complete installation
Try printing a test page from the printer itself. This will determine if it's a communication issue or the printer itself
Jul 26, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
533 people viewed this question
Seeker5211
Seeker5211
