Lg tromm wm2377cs
Washing machine just quit and wont turn on. Tried all obvious things ie. breaker/power etc.
5 Suggested Answers
SOURCE: my lg tromm washing machine has an error code LE
Empty Washer and unplug. Hold the start button (arrow with two lines) for 10 seconds. Plug back in and put on the Rinse and Spin cycle (right hand side) I went ahead and ran that cylce (31 minutes with some bleach) and all worked well.
If problem persists call CSR. 800-243-0000
Posted on Sep 20, 2009
skimbot
  • 5 Answers
SOURCE: LG Tromm will not turn on.
I have put mine on a surge protector. It is a computer after all. It is hard to say whether or not you have suffered damage to the motherboard. Trial and error testing to see if you have power at your outlet. Hopefully you can repower and all will be well.
Posted on May 30, 2010
jyackle5
  • 8197 Answers
SOURCE: manual for LG Tromm wm2277hw
You can get the manual on the link below.
http://www.manualsonline.com/mdownloads/2cae013d-c99d-4af1-a802-a2d4c42197df.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 29, 2010
heatman101
  • 43501 Answers
SOURCE: LG Tromm Washing Machine Won't Drain code
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Posted on Nov 16, 2010
LG Tromm Washing Machine no power unless I unplug it and reset it.
See if you can lift the top of the washer by unscrewing it from the back and you should find a code and test sheet in there. Very easy to follow and run the test.
Jan 02, 2016 | LG Washing Machines
I have a LG Tromm with an LE error code. I just replaced the hall sensor
With a digital volt meter you need to measure the ohms value of the hall sensor. It has 4 wires. White red blue and gray. With the meter set at 20k ohms check hall sensor at the control panel. From white to blue you should read 9.5 K ohms. Same with white to red. If u get 9.5k ohms on both readings u have a bad main board. However to me I think your pump is bad. LG washers will not spin if they don't drain.
Apr 03, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG washer (Lg tromm Wm2377cs) is coming on by itself when the door is open. The panel stays lit, then eventually goes dead, only to come on again later by itself.
not just yet? still need to check other items? the timer, the push start? etc buying a new board may not solve ur issue less ur sure of the cause, the door actuator may be stuck closed however cant see how it would effect the start staying continually on so I would check both out at the least
Mar 08, 2013 | LG WM-2277HW Front Load Washer
The door gasket on my LG Tromm WM2377CS washer always has water trapped in it. The three tiny drain holes have been getting more and more clogged with "gunk". How to get the drain holes cleaned...
I use nylon cable (zip) ties to clean them. (Not sharp, so no danger of poking holes in the gasket) You may want to run a washer cleaner through the machine occasionally, such as Affresh or Washer Magic, or one made by Tide or Clorox.
Jul 23, 2011 | LG WM-2277HW Front Load Washer
Not completing cycle error IE
IE is a water supply error. turn water off to machine and unscrew your 2 water hoses on back of machine and clean inlet screens with old toothbrush. if they are clean, you probably have a stuck closed water solenoid.
Jul 25, 2010 | LG WM2277H Front Load Washer
May 25, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg dle0442w wont dry clothes blows cold air
Sometimes it is the heater element in the dryer. Other times the main circuit breaker has tripped one leg. Some 220V-230V breakers have two trip switches that are tied together. One half of the breaker runs the motor and the other half operates the heater. A defective breaker can also cause the problem.
Jun 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM WM2233HS won't start
Obviously I switched the breaker wrong. We switched the breaker again and it worked.
Apr 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg washing machine error code is ie
IE = inlet error. Washer has not detected enough water after 8 minute fill time. Check screen at inlet water valves where hoses connect to machine for blockage. Look for kinked hose(s). Make sure there is water supply reaching machine. If all OK, most likely next thing is the water valve itself.
Sep 02, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
