Question about Hotpoint First Edition WMA22 Front Load Washer
Water not pumping out
The machine is not spinning and getting rid of water. have tried putting programme onto spin only but nothing happening.apart from wash Previous machine pump had a filter you could access to check for blockages but can't see an access point on this machine Anybody any idea ?
  • Samuel Charles Spriggs May 11, 2010
    Does most of the water drain before it gets to the spin cycle or is the machine still full?
  • Hotpoint Master
  • 3,463 Answers
Filter is located at bottom rear right of washer, inside large black hose.
Remove lower rear panel to gain access.
Please rate my solution.
Thanks.
Posted on May 31, 2009
What could be wrong with my Miele Novotronic premier 500 If I use the drain/spin the machine makes a grinding noise which I~ don't hear when I use the washing programme
hi my guess is that as the machine is on drain & spin that is the time when the pump which drain the water is turning to empty the water and hence it also on when on spin to get rid of the water .
I think you may have a foreign body in the impeller of the pump , ( paper clip , a pin needle etc., ) usually by removing the filter which is located by the pump you will find foreign body in the filter but sometime these clips /needles / nails they get imbedded in the pump housing with long nose pliers they will pull out , but be careful not to puncture the pump housing
Nov 24, 2017 | Miele Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Not spinning and goes back to start of programme
Sounds like a problem we had on are washing machine. I assume that the you have confirmed that the pump has removed the pre spin water ?
We found the problem that the small pipe to the sensor from the sump area had a split in it. The sensor could not detect most of the water had been pumped out so it kept trying to empty
Jan 08, 2014 | Washing Machines
The washer has stopped emptying and spinning. The pump does not appear top be making any sounds either.It is a hotpoint aquarius
OK... Pessure switch is proberbly stopping the machine from spinning due to the water level in the machine... The pump could have just stopped working, or, the control board could be broken and therefore the pump not getting a supply current, or, the propeller in the pump could be jammed by debris.
1. Turn the machine off, and unplug...
2. Take the drain pipe and lower it to an outside door or other place to safely drain the water away that is still in the drum.
3. Follow the drain pipe till it reaches the pump. Check the lead to the pump to make sure it is properly engaged into its recess on the pump motor.
4. Take the hose off the pump in order to clear any debris and then replace the hose
5. Having done all that, plug the machine in and turn it on
6. Put it onto a spin programme ... The machine should now lock the door, then both pump and spin actions should start... If not, your control board or cabling is at fault
Aug 20, 2009 | Hotpoint Washing Machines
Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
May 20, 2009 | Maytag Washing Machines
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
Hotpoint WMA30 Front Loader Not Pumping Out but still fills if put on rinses, on spin tries but gives up
no easy way to get water out but try putting drain hose down at floor level into a bucket and that may work
fault is probably filter blocked.
to access filter, take rear back panel off. you will see a large diameter hose going from bottom of tub to pump. disconnect this hose at tub end - carefull, water will come out. filter is inside this hose. take it out, clean and reassemble
Oct 02, 2008 | Hotpoint WMA30 Front Load Washer
We have a Bosch Exxcel Washer Dryer and it seems that at the end of any programme, the washer does not drain and spin (but does drain and spin in independent programmes) - it just continues at 0.01 mins...
would try cleaning your pump and sump as when its draining without the force of the spin the pump is idle but with the force when you put on other programs ie the spin this will push the water through the pump hope this helps
Jun 22, 2008 | Washing Machines
Hotpoint WMA50p won't spin
Had same problem today with our machine. Brushes looked OK (although one appeared a little shorter than the other).
After removing and re-fitting the brushes, motor worked fine - suggesting that it was the brushes afterall.
Now looking for replacement brushes
Feb 19, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint First Edition WMA22 Front Load Washer Logo
194 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
