Question about Classic Minicooler Mini Cooler / Warmer ThermoKool Deluxe Mini Beverage Cooler
Where can i find a power cord for a minicooler RF 10 11 12v model #03044182
How do I reset error code SC548
25685181-yl5nsd0dwyytd1n2wv4v20hl-5-0.jpg OR
Sponsored Link Shop Bulk Wire & Cable
Network, Telephone, Coax & A/V. Quantity Discounts & Same Day Ship!
showmecables.com/Bulk-Cable STEP 1 Purchase the RF modulator at an electronics store. The modulator is used to connect your older television to cable.
STEP 2 Plug the RF modulator in a power outlet near your television. It is best to plug it near the television to allow for easy access.
STEP 3 Connect your television to the RF modulator by inserting the one-prong cord that is on back of your television. Insert the cord in the slot on the modulator that reads, "To TV." On older televisions, this cord is the only cord in the back.
STEP 4 Connect one end of the white one-prong cable to the cable box and the other end in the RF modulator. Connect it into the modulator in the slot the reads, "ANT IN." Usually, the cables are provided by the cable company--the technician uses them upon installation. This particular cable may run along the side of the wall to your cable box.
STEP 5 Turn on the cable box and the television set. Everything should be working properly. On the RF modulator, choose the channel for the television (either channel 3 or 4). The modulator turns on when you plug it in.
May 08, 2015 | Office Equipment & Supplies
I have a maganovox combo system, converter box, older model zenithe tv and rf modular. How do I connect all this to record and look at vcr on combo? I need step by step of hooking up all cords and plugs....
You dont need the rf modulator. Use a female to male rf, antenna cord and plug from the RF out on the back of your combo to the TV. Now you need to tune your TV on analogue mode until you find the dvd/vcr picture. Have the combo on when you're doing this.
Feb 19, 2014 | Televison & Video
Traxon RF 10-11 Need the power cord
RF-1011-12V PLUG IN 12V DC (POWER IS GOOD) AND NOTHING HAPPENS. NO LIGHTS OR FAN. I CAN NOT FIND MY OWNERS MANUAL. CAN YOU ADVISE? THANKS DAVE
Aug 02, 2011 | Classic Minicooler Mini Cooler / Warmer...
When ever i dead key the mic on med rf power i get a humming or bumble bee sound through my talkback same thing on high rf power i changed the coax it helped it for low rf power and tried new mic but had...
Thats because your Rf is powerful on high settings..try taping a AM radio "ferrite bar" to your coax in the back of radio for "RF filtering". Keep your power supply 15 inches away from radio. I recommend unhooking talkback on radios (it always causes feedback). But make sure speaker is good distance from the radio. I'd say 10 feet or so, behind radio. Change external speakers or add one with a long cord.
Apr 23, 2011 | Ranger Virage VX-38 Base CB Radio
Can you hook up a super nes without AV cords? I have 2 cords, 1 is power and 1 connects to an antenna-like input.. do you need AV cords aswell??
It is called an RF connector.Plug your cable coming into the house from outside into the RF connector,then plug the RF connector into the TV.The TV needs to be on channel 3 or 4,depending on what it is set on the console,to use the console.There should be a selector on the console back.If there is a strong broadcast on the channel you select to use,just change to the other channel.If you have the proper channel,the TV signal will go away and the game will appear.You do not need the A/V cables.
Jul 23, 2010 | Nintendo Super NES Console
Does the coaxial output equivalent to a standard yellow cord video cord? Trying to transmit Direct TV signal to another TV via a RF Link.
Typically the coax is an rf signal. The "yellow cord " is a video signal and never the twain shall meet without an rf modulator. rf contains all video, audio, and sync signal. Video contains just video, no audio. If you use the yellow, and the white and the red you will have video and both audio channels.
Oct 16, 2009 | Olevia LT27HVX 27 in. LCD Television
I have a cobra 29ltd crome had echo board installed works good till i trun my la 900 on get feed back or squilling how do i fix
LA 900? I am guess that is a linear amplifier. If so are you running a power mic? You are probably getting RF feedback. You need to turn the gains on the radio and mic down.
Some things you can try. Hold the mic cord in your other hand in the center of the cord while you key it. some times this will shield it form stray RF.
You can also get a bunch of RF chokes from radio shack. They are little black things you snap onto wires that shield form RF. Put 2 near the plug, and 2 near the mic. That will help shield it from RF.
you will most likely still have to play with the gains on the radio and mic to find a sweet spot where it doesn't squeel.
Oct 06, 2009 | Radio Communications
Manual
Check its site for supports and downloads. You will be able to find it, but this is a very less probability. Because it normally doesnt come on sites for such home appliances.
Thankyou
Jun 17, 2008 | Classic Minicooler 550XX Compact...
Home Audio Bose 48 - Remote not working
Had an issue with the Bose Remote RC38t1-27 not working at all. Changes batteries twice to no avail. Called Bose Tech support who walked me through the fix. I unplugged the power cord connected in the back of the system. Waited for 30 seconds or so and plugged it back into the system. Also made sure the power cord was uncoiled/unbundled as the RF (Radio Frequency) signal is within. Bingo!
Aug 05, 2007 | Bose Lifestyle 48 System
Classic Minicooler Mini Cooler / Warmer ThermoKool Deluxe Mini Beverage Cooler Logo
42 people viewed this question
Top Classic Minicooler Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Classic Minicooler Refrigerator Expert? Answer questions, earn points and help others
