Question about Black & Decker Leaf Hog Blower Bv4000
Blower will just not turn back on - Black & Decker Leaf Hog Blower Bv4000
Heater blower stopped working
Check your fuse, then you need to know if your blower is blocked or sceized, leaf, ice, any rubish
Jan 13, 2014 | Cars & Trucks
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
Blower motor wont turn off
It could be the blower relay. You would need to start at the blower motor and trace the wiring back to the relay to find out.
Jul 01, 2013 | Pontiac Bonneville Cars & Trucks
The blower will not blowair
Commonly caused by a bad 'blower resistor'. You'll need to search online - Google: Safari blower resistor or Astro Blower resistor - on WHERE the resistor is located.
GL,
Td
Oct 10, 2012 | 1992 GMC Safari
The blower doesn't blow when I turn the air or heat on but the blower in the back works fine the knob from higg to low is stuck in the middle and I can't get it to move
Have you tested the front blower motor with a test lead hooked to 12 volts? Use a length of lamp cord and make up a jumper to test the blower, replace as necessary. Also inspect the connector to the blower for signs of melting or burning, replace as necessary.
Apr 20, 2012 | 1999 Mercury Villager
Blower motor will not come on. i have a rheem furnance
Turn your fan from auto to on at thermostat, if fan doesnt come on.
Remove blower motor door to get to control panel-Turn poweroff !
Try to turn blower wheel to see if it will turn freely,
Remove thermostat wires from control board, put a jumper wire between
r and g.Put door back on and restore power, fan should run. If it does
than it is possible you have a burnt out speed on whatever cylcle heat/cool you are trying to use.
To troubleshoot this-turn power off and find where the blower wires go to
control board. exchange the wires from park to heat or cool terminals.
put cover back on and restore power.IT should work,if nothing happens then you probably have a problem with blower
Feb 13, 2010 | Heating & Cooling
AC BLOWER MOTOR GETS HOT THEN TURN OFF.
I HAVE A 1998 CADILLAC DEVILLE,THE AC BLOWER MOTOR GETS HOT AND TURN OFF AND WONT TURN BACK ON UNTIL IT COOL OFF, WHAT IS THIS PROBLEM?
Jul 04, 2009 | 1999 Cadillac DeVille
Blower fan comes on high only after 5 mins.
Maybe a relay which is under the blower motor under hood or a blower control module or resistor depending on the ac system you have.
Apr 23, 2009 | 1992 Buick LeSabre
No heat in front but back heat is working
could be a blower motor resistor or a faulty blower motor. if no air is coming out of the vents when you turn the switch to on there is a fault in the electrical system somewhere. the rear blower system is pretty much totally separate from the front so therefor rear hvac is working properly. test blower motor resistor and blower motor current and see if its putting out any power also make sure the wires going to the blower motor are hot also.
Mar 04, 2009 | 2002 Dodge Durango
Black & Decker Leaf Hog Blower Bv4000 Logo
46 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
