Question about Geovision 32 Channel NVR Software License Third Party IP Cameras
GeoVision NVR Software for 3rd Party IP Cameras
    Habit-Forming:
  • 106 Answers
Not exactly sure of the question but Geovision does allow for many 3rd party IP cameras to be connected. Check the Geovision website for a full compatibility list. I have personally worked with Hikvision and Vivotek with no issues. You will need to purchase and install a dongle. The dongle comes with software that you will need to install before using the USB dongle. The dongles come in 1, 2, 4, 8 & 16 camera capabilities. There is usually no cost difference to buy two 2 camera dongles or one 4 channel dongle. So get whatever you need. Just be aware that is will look odd having 4 USB sticks protruding from your NVR. There are also some internal dongle options that connect directly to the motherboard.
Posted on Jan 04, 2015
SOURCE:
With is nvr security
NVR = Network Video Recorder.
HD NVR camera systems - Lorex
https://www.lorextechnology.com/hd-nvr-camera-system/N-p3cgve
  1. Cached
Rating: 8.7/10 - ‎2,276 reviews Results 1 - 21 of 42 - Security cameras systems with HD NVR. ... Lorex HD NVR security camera systems provide stunning 4K,2K and1080p video that leaves nothing to the imagination. ... For crystal clear HD video quality that you can view from anywhere in the world, stay connected with a Lorex HD NVR camera system ...
HD IP NVR Systems ' Costco - Costco Wholesale
https://www.costco.ca/hd-ip-nvr-systems.html
  1. Cached
Find a great collection of HD IP NVR Systems at Costco. Enjoy low warehouse prices on ... Electronics · Surveillance & Security Systems. HD IP NVR Systems.
Surveillance Security Systems - Newegg.ca
https://www.newegg.ca/Surveillance-Security-Systems/SubCategory/ID-693
  1. Cached
LaView LV-KNT982A42W4 4 MP zoom HD 8 Channel NVR PoE IP Security System, with 2pcs 4 MP (2688 x 1520) and 2pcs 2 MP (1920 x 1080) Bullet Camera ...
Jul 13, 2017 | Home Security
How do i sync my swann H-264 8ch sercurity system through my t-mobile onetouch evolve
I would guess that you would hook it up to the internet source and find the IP you are given or assign yourself one. Then it is oossible to look at that IP address to see what is on the NVR
Jul 04, 2015 | SWANN Home Security
Settings on camera
The settings on the camera can be accessed by searching for your camera on your network. 1. Connect the IP camera to your network making sure to use the correct power supply or POE switch. Then use the GGV-IP Device Utility which can be downloaded for free on the Geovision Website. This utility will find all of your IP cameras by IP address. To access the camera, use the default user name and password of admin/admin. You can update the camera settings including the IUP address, gateway, subnet mask, etc by choosing the updating settings section and then inserting the user name and password.
Jun 30, 2014 | Geovision Gv1480 32 Ch Dvr Card Gv-1480 A...
DVR Cplete Hung & freez
sounds like a software problem. could be on Windows or on the NVR software. best bet is to re-install windows formatting the hdd completely. once done re-install the NVR software. if that does not solve your problem have a look at the graphics cards in the unit as well as the hdd. they could be faulty.
Dec 09, 2013 | Avermedia AVerDiGi SA6832E RACK 32-Channel...
Geovision ip camera is fuzzy over internet
It could be your internet streaming that is causing the issue. Too little bandwidth. You can also check the settings for your substream quality. Inside the DVR check the settings for the cameras.
Jan 30, 2013 | Geovision Home Security
Will the GV-FE110 Fisheye IP Camera need the Capture Card?
No. None of the IP cameras require a capture card. Instead the included Geovision software can be used to record the video. That's the beauty of Geovision. Good software at no cost when you use their cameras.
Jul 20, 2011 | Geovision Gvfe110 13 H264 Fisheye Ip...
GeoVision GV-BX110D cameras unexplainably changing from color to black & white. Geovision NVR
This has to be caused by either a setting in the camera or the light level. If this is not the case, you probably need to RMA the camera. This is not normal unless the aperature is set wrong.
Jun 02, 2011 | Geovision NVR Lite Box Camera System 4 X...
Hello I am getting to theGV-800 Geovision pag...
I am not sure what trouble shooting you have already done but a few of the basics are.
1.you cannot connect to your own Geo Web server within your own network, you will have to do it from outside. you can connect within if you use your internal ip address.
2.make sure your router is open for incoming and outgoing connections on ports 80, 4550, 5550.
3.Try connecting without the router if you have one.
4. Geovision works with internet explorer only, not Firefox,, try the DMmultview program that came on your software disk.
try those suggestions first
Regards
Marvin
May 19, 2010 | Geovision GV-800-16 Video Capture
Static ip problem
I know this is late but the IP address you are probably trying to access is a private IP. You need to find your public ip address in Egypt by going to www.whatismyip.com Once you do this you need to forward all the ports used by Geovision to the static IP address you have given your DVR.
Dec 10, 2007 | Geovision GV-650 BNC (GV6504) Video...
Geovision 32 Channel NVR Software License Third Party IP Cameras Logo
213 people viewed this question
Top Geovision Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Geovision Home Security Expert? Answer questions, earn points and help others
