Washing machine is overflowing in the rinse cycle
It is overflowing in the rinse cycle, but only sometimes. I have tied filling it just half way and setting the load size to medium and it still overflows. I tried unplugging it while it is filling w/ water and when it's unplugged it stops filling. Suggestions, please?
  • 3 more comments
  • asch803 Apr 23, 2009
    no, i don't know how to do that...i also have the problem that space is very limited and i have a very difficult time accessing the back of the machine and cannot move it out from the wall more than a few inches.
    the make is Admiral 22 Mega
    It is a top loading washer...how do i pop the lid of the washer? Is this a repair that i can do myself or do i need a service call?
  • MIKE major May 11, 2010
    what make,is it a top load?it sounds like the water level hose might have come loose or the water level switch is bad,let me know
  • Samuel Charles Spriggs May 11, 2010
    There is probably an obstruction in the hose which is part of the water level sensing subsystem. This is usually a small (3/8" - 1/2") clear hose which runs up the side of the tub. To see it, you'll have to pop the lid of the washer. Do You know how to do this?
    Genius:
  • 1,122 Answers
The front panel comes off,i think there is 2 screws on the front bottom,if not there should be spring clips in the top front seam on on each side,check the clear hose going to the tub,make sure nothing is in it and it is on tight,check the other side of the hose is behind the head panel,do the same there,if they both go good then you have a bad water level switch,let me know
Posted on Apr 23, 2009
    President:
  • 1,489 Answers
Well, it sounds like you need a service call. The fix is probably one of the cheaper ones you could encounter -- but be prepared.
Charlie
I have a GE front loader washer and on the rinse cycle it stops and counts down.
Most washers now have a cold rinse only per government requirements. If you have the cold half of the inlet valve bad or sometimes blocked with sediment it will not fill for the rinse cycle causing the problem you have. The inlet valve is the part your house hoses hook to on the back of the machine.
Mar 07, 2015 | GE Washing Machines
Kenmore 80 series washer will sometimes not fill in rinse cycle, sometimes half fill, sometimes 1/4. fills fine for start but not rinse????
HI, This will be the result of a failing control sector. The control sector can be a timer module, or a single printed circuit board. In any case, this will be your culprit. Have this damaged control replaced, asap. Once replaced, your unit will operate correctly.
Dec 26, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't fill up
how old is it? if it is pretty new make sure your drain hose is not too far down the drain whole 6 inches is plenty get something and tie it up if you pull it out of the hole and you hear a gurgling sound that is your problem give it a shot let me know
Mar 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
My Roper top loading washing won't stop filling.
It's not necessarily the angle of your drain hose. When it drains as you fill it, it's called a siphon condition. Pull the excess hose out of the stand pipe (drain). Only about 6" should remain inside the pipe. Tie it down with a plastic tie to one of your fill hoses to prevent water pressure from pushing it back out. This should solve your problem.
Nov 10, 2007 | Roper RAB2121KW Top Load Washer
Washing machine overflows
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 24, 2007 | GE WJSR1070A Top Load Washer
Lavamat 6955 sensorlogic - carries on filling until water overflows from soap tray
fault f1 is slow or no cold fill. this fault code with overfill points to: air chamber blocked with sludge hose from air chamber to pressure stat blocked or split pressure stat faulty of these the first is the most likely
Dec 12, 2006 | AEG Lavamat 88840 Front Load Washer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
